Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 07-25-2007, 08:55 AM   #1
bluestraw44
bluestraw44 Normal reputation
92 Accord EX - tough to shift out of park
I have a difficult time getting my 1992 Honda Accord EX automatic with 150,000 miles out of park. I adjusted the shift cable according to instructions and lubed all related parts. Is there something I can do on the exterior (transmission side) of the cable that might make a difference?
Once out of park, it shifts into R, N, D4, D3, 2 and 1 perfectly fine. Getting it back into park is a little stiff and you have to press firmly to hear the click that tells you it's back in P.
Any thoughts, suggestions, advice most appreciated.
bluestraw44 is offline   Reply With Quote
Old 07-25-2007, 09:10 AM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
jeffcoslacker Normal reputation
Re: 92 Accord EX - tough to shift out of park
Sure the problem is not in the shifter grip's detent button, and not the linkage at all? They sometimes wear out and make pushing the button in not as effective as it should be, which makes park difficult like you are describing.
There's a kind of "ramp" thing in there that wears out, and pushing the button in doesn't fully depress the vertical rod portion that runs down the shifter to the detent. If there's a allen screw or something on the shifter handle, take the handle grip off, and see if pressing the rod directly makes the shifter move easier..
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 07-25-2007, 10:37 AM   #3
bluestraw44
Thanks for the reply.
I had the whole area exposed, and pressed down on the center rod without the shift handle and it acts the very same. I even took out the part that rolls into the grooved (notched) piece thinking perhaps it was worn, and even without that piece in place, it was still difficult.
Old 07-25-2007, 01:42 PM   #4
jeffcoslacker
Huh. Maybe you can adjust the cable stop at the tranny case or something...I don't know.
Sounds like the cable travel doesn't quite reach the end of the shift selector's travel on the tranny, puts the shifter in a bind once in park, has a hard time reaching it going into park..have someone move the shifter while you watch the selector on the tranny case move...you might get some inspiration or see something that's interfering or something...good luck with it.
...empty gun rack.
Old 07-27-2007, 08:05 AM   #5
bluestraw44
I removed the cover around the tranny side of the cable, sprayed WD40 where the cable connects and it seems to be better! Thanks!
Old 07-27-2007, 11:35 AM   #6
jeffcoslacker
Cool. If that works out, I'd go back over it with some white lithium...WD-40 won't last long down there...
...empty gun rack.
Old 08-11-2007, 07:54 PM   #7
roann12
roann12 Normal reputation
Thank you for the info., I,m having the same problem with my 91 Accord LX
Sorry i wrote on this page. I,m a newbee
roann12 is offline   Reply With Quote
Old 08-12-2007, 10:23 PM   #8
chubbygoatboy
chubbygoatboy Normal reputation
Shifter cable needs replaced
chubbygoatboy is offline   Reply With Quote
Bookmarks
Google
Web AF
