HELP 91 p.a. codes 16,23,21,43,68.etc.rtthib 07-23-2007, 10:26 PM i am having high and low spikes in voltage to my tps, tranny, cruise, getting false temp reading in intake. fans not coming on causing overheating. electronic spark failure. voltage to battery will jump as high as 19 volts for a few seconds . tps will spike high for over 4 seconds. i have change alternator twice , battery, and a belt that needed replacment anyway . also i have been having trouble with no low beams lights. yesterday i chaned the battery and the positive cabel. the local buik garage would not help me in any way. they said they no longer worked on cars 10 years or older please hilp ridky thbodeaux in louisiana HotZ28 07-26-2007, 05:26 PM Your problem could be that the ECM has gone defunct. Hard to dignose without a scanner reading live data. If the sensors are sending the correct voltage input to the ECM, the ECM should show the same input on the scanner display. the local buik garage would not help me in any way. they said they no longer worked on cars 10 years or older BTW, this is for your local "buik garage"! :evillol: :nutkick: rtthib 07-27-2007, 09:52 AM the scanner was giving me readings of the battery=19-2 volts. tps high votage for more than 5 seconds . and a few other places. dammed wrightz28 07-27-2007, 10:01 AM Whoa, is that supposed to be 19V high and 2 volts low?!?! :yikes: I believe that the voltage is regulated by the ECM after 90 or so. So backing up Hotz28's statement, sounds as if Elvis has done left the building (and took your ECM with him) :( HotZ28 07-27-2007, 11:31 AM sounds as if Elvis has done left the building (and took your ECM with him) :(:rofl: You may be able to get your ECM back if you can find Elvis! The King is alive!:grinyes: :iceslolan BTW Dylan, that was a good one! :rofl: :rofl::rofl: Automotive Network, Inc., Copyright ©2012
