Car Alarmrgaut153 07-23-2007, 09:26 PM Ok, i just bought a 95 integra. Some how the alarm turned on and now i cant turn it off. Im prety sure its after market. I dont have a remote to it and iv tried disconnecting the negative terminal...that didnt help. I cant start the car now and im lookin for some help. I disconnected the siren so it makes no noise but i cant deactivat it. I also dont think i can get the remote. What should i do? somick 07-24-2007, 11:36 AM My aftermarket alarm has so called valet switch. I have to press it repeatedly untill the alarm stops. Since this is an aftermarket, there is no exact place where they put it. Mine is taped inside the fuse box. On my son's car there is tiny toggle switch under the dash. You need to look for the switch and then play with it. Or try to find a unit and disconnect power to it. Once again there is no exact location for it. Good luck, Sam 00accord44 07-24-2007, 03:45 PM Both remotes for my alarm were broken so I just pulled the fuses for it. Try looking in the mess of wires thats underneath your guages and see if you can isolate the ones for the alarm. Mine has (had) a fuse for main power supply and one for remote entry relay. Like somick said there's no specific place to find any aftermarket wiring since its up to the discretion of the installer for where they want to put it. You may be able to follow the wiring from the siren under the hood to find the cluster that leads to the right fuse(s) Automotive Network, Inc., Copyright ©2012
