96 Outback Dash Lights and Parking Lts Blinking
Google
Web AF
Smith1000
07-22-2007, 11:38 PM
I cleaned the pos. battery post and ever since putting the cable back on the battery, the dash lights and tail lights have been blinking. Sounds like there is a flasher unit in there clicking. It does this with the key off or on. I have to disconnect the battery to keep it from running the battery down. It pauses occasionally, but starts back up. Is there something that needs resetting? Not sure what the problem is. Thanks.
TIFFW
09-23-2007, 02:26 AM
98 outback exact same problem? Help
kfenske
01-21-2008, 05:08 PM
How to reset blinking lights in 96 Subaru Outback after batter disconnect
When you disconnect the battery then reattach it the car goes into a “tamper” mode and the parking lights blink forever.
To reset this do the following:
1. Put key in RUN position in ignition
2. Lock doors using power locks
3. Way up under driver side dash on left is a button inside a rubber cylinder. This button hanging there at the end of a wire and is called the valet button. Click and hold this button for 10 seconds until the electric door locks lock and unlock 3 times.
4. Lock and unlock doors
Done
kathryn689
11-27-2008, 02:07 AM
thank you so much! you are a life saver!
Google
Web AF
