4.3w low powerPages :
[1]
2
5693dtcd 07-22-2007, 03:05 PM Hello- I have a 2000 Blazer with 123,000 miles. It currently has very low power. I cannot get any acceleration out of it. The exhaust sounds like the engine is running against itself. I have been struggling with this for a year now. I do most of my own work. At first I thought the exhaust was plugged. Midas put on a new convertor and muffler. No change. The plugs, wires, cap and rotor are new. I then broke down and took it to a dealer. They said the exhaust is plugged. I took it back to Midas. Put a 2nd convertor and muffler on. No change. Tried to go on vacation pulling a smal camper- Problem got worse. Had another GM dealer look at it - could not determine problem. No check engine light. Since then I have- Installed new intake gaskets New fuel filter New fuel pump New timing chain Tried a used ignition module,coil,and fuel injection spider. All of these did nothing. The fuel spider actually made it worse. I have had it hooked up to a Snap On computer. All the sensors appear to be doing what they are supposed to. The problem is in the timing. At idle it is 20 BTDC. Try to throttle up and it starts to advance but when the engine hits around 3000 rpm the timing retards to less than 10. The timing is not advancing like it should. The knock sensor and MAP sensors are both creating the proper voltage signal to the ECM. Shop floor no load RPM's rarely get over 3500. When they do the timing is not retarding as far. What else can affect timing? This is my first posting. I have been able to try other ideas that I have seen posted here on this web sight. Thank you for reading. MT-2500 07-24-2007, 01:58 PM Check engine vacuum at idle and at 2K rpm and post back vacuum readings. What were the camshaft retard readings on the scanner? How is the fuel pressure? AJT1961 07-24-2007, 03:37 PM If you ever find the cause, PLEASE make sure to post the fix. I also have a 2000 Blazer (125,000 miles) that suffers from relatively low power despite more-or-less everything being new AC Delco parts, good oil and fuel pressure and no codes whatsoever. I can live with mine, but I know the power is not nearly what it should be, and I wouldn't even try to tow with it. I have been monitoring the board for quite a while now, and it seems that there is some problem peculiar to 2000 Blazers that causes this problem -- although I've never seen a solution. Whenever I have seen a "low power" post with no other problems, more often than not it seems to involve a 2000. A somewhat odd sidenote -- a little while after I replaced my lower intake gasket, I ran a quart of block flushing solvent in the crankcase for the recommended number of minutes, drained it and put in fresh oil and filter. During the test drive, it rode like I had installed a supercharger on the vehicle -- the increase in power was beyond incredible -- it seemed even better than when I bought it new. After that, the power gradually decreased over a few hundred miles and went back to "normal" since then, which was over a year ago. I've always changed the oil and filter every 3000 miles from new, so I assumed it was not a general sludge problem. I don't know what any of this means (is there some offending senser that the block flush temporarily cleaned?), or whether it could be related to the problem you are having. But anyway, good luck finding your problem. need_a_new_truck 07-24-2007, 06:01 PM Did you have the problem before you installed new intake gaskets? AJT1961 07-24-2007, 07:05 PM Yes. 5693dtcd 07-24-2007, 11:12 PM Check engine vacuum at idle and at 2K rpm and post back vacuum readings. What were the camshaft retard readings on the scanner? How is the fuel pressure? Thank you for responding. I do not have a vacuum gauge. The MAP readings on the scanner are 10.7" HG at idle 1.36 V at idle 8.9" HG at 2000 RPM 1.0 V at 2000 RPM As long as the MAP sensor is good these readings should be accurate. Should this be confirmed with a gauge connected directly to the manifold? Camshaft retard is at -11 degrees both at idle and 2000 rpm. Fuel psi is 60 psi peaking at 65. I installed a new fuel pump and inline filter. The reading had been 55 psi. The new pump made no change at all in the power. I work in parts at a medium duty GM dealer. Some of the techs at work thinks it is the injectors. They test good on the scanner. I realize this only checks them electronically. It would not detect a bad spray pattern or uneven fuel delivery. I tried a used fuel injector spider but who knows how long it had sit or how many miles were on it. I may try a new one this weekend. Has anyone changed them and how many miles did you have on the truck? Did you gain power? 5693dtcd 07-24-2007, 11:18 PM Thank you for responding. The problem did exist before I changed the intake manifold gaskets. Even though I could not find an exhaust leak( by spraying carb cleaner around manifold) I was at wits end. The old gaskets looked good coming off. The new ones did not make it better. I have been working this problem fo a long time. I am starting to suspect the injectors more and more. (see other reply) I have a friend with a 2000 Blazer with this same problem. A lot of people I talk to though say this 4.3 L is a good little powerful engine. Mine used to be. AJT1961 07-25-2007, 03:39 AM >>Has anyone changed them and how many miles did you have on the truck? Did you gain power?<< I replaced the OEM spider in my 2000 (currently 125,000 miles) with the recommended replacement GM unit about 10 months ago. My old unit's pressure regulator was leaking down causing hard starts. It solved the hard starting problem, but did nothing whatsoever to improve the low power problem. I am thinking about replacing the Oxygen sensors (mine have never been replaced) even though I am getting no codes and it passes emissions easily. Have you tried replacing your O2 sensors? MT-2500 07-25-2007, 10:53 AM Thank you for responding. I do not have a vacuum gauge. The MAP readings on the scanner are 10.7" HG at idle 1.36 V at idle 8.9" HG at 2000 RPM 1.0 V at 2000 RPM As long as the MAP sensor is good these readings should be accurate. Should this be confirmed with a gauge connected directly to the manifold? Camshaft retard is at -11 degrees both at idle and 2000 rpm. Fuel psi is 60 psi peaking at 65. I installed a new fuel pump and inline filter. The reading had been 55 psi. The new pump made no change at all in the power. I work in parts at a medium duty GM dealer. Some of the techs at work thinks it is the injectors. They test good on the scanner. I realize this only checks them electronically. It would not detect a bad spray pattern or uneven fuel delivery. I tried a used fuel injector spider but who knows how long it had sit or how many miles were on it. I may try a new one this weekend. Has anyone changed them and how many miles did you have on the truck? Did you gain power? The vacuum gauge check test for restricted exhaust system. You can pickup a vacuum gauge at parts place or tool dealer cheap. One of the first and cheapest test tools made. Yor camshaft retard reading/setting is bad. You need to bring it in as close to 0 degress as you can. Shoulds not be over -2 or + 2 degrees at the most. If the no adjustable dist and off 11 degres you may have to remove dist and turn the dist gear a half turn to get it back in. Rebuilt or exchange dist sometimes the gear not timed/set right. A half turn will change it around 10 to 12 degrees. http://files.automotiveforums.com/gallery/showphoto.php?photo=51302 MT-2500 07-25-2007, 11:08 AM Unless you are on top of a mountain 10 in hg maf sensor reading is not good. What is you sea level altitude? Do you have any fuel trim short or long term readings? In. hg at 2000 ft should be around 28 in. hg and 29 at 1000 ft. blazes9395 07-25-2007, 12:18 PM Yor camshaft retard reading/setting is bad. You need to bring it in as close to 0 degress as you can. Shoulds not be over -2 or + 2 degrees at the most. If the no adjustable dist and off 11 degres you may have to remove dist and turn the dist gear a half turn to get it back in. Rebuilt or exchange dist sometimes the gear not timed/set right. A half turn will change it around 10 to 12 degrees. http://files.automotiveforums.com/gallery/showphoto.php?photo=51302 This IS a big problem, you may have found your problem. My opinion, you need to get this figured out. Follow MT instructions, half turn and get it dialed in to the proper settings and go from there. 5693dtcd 07-25-2007, 07:03 PM Hello- No, I have not tried to replace the O2 sensor. They have passed and are fluxuating like they should. With the reply concerning the cam retard it looks like I beeter look at the distributor again. (see other replies) Thanks for your response. 5693dtcd 07-25-2007, 07:17 PM The distributor is fixed. I have taken it out but I was very careful to put it back in where it came out. I will investigate further though. The GM tech that worked on it earlier this summer told me about a reference point on the dist. There is a small 6 and 8 cast into the housing of the dist. On a 6 cyl with #1 at TDC the rotor should point at the 6- likewise on an 8 cyl. Thanks for your reply. According to the local airport we are at 597 feet above sea level. 5693dtcd 07-25-2007, 07:18 PM I have removed the distributor but was aware of engine position and TDC. I will inspect the drive gear. Could it be wore out? I tried a used dist. out of an engine that had blown. Now that I've typed this it makes me wonder it the dist. was bad in this engine and he just drove it till it blew! 5693dtcd 07-25-2007, 07:23 PM Thanks for the bulletin. That is very helpful. I am confident that the exhaust is not restricted. The original dist. is in the truck now. I started having this problem before I removed it. I remove it to try a different cam position sensor. Thanks for your reply- I've got some things to check out. MT-2500 07-25-2007, 07:57 PM You should be reading about 29.5 -29.4 Give it a good cleaning with MAF sensor cleaner and reset PCM and see what it reads. Good luck MT 5693dtcd 07-27-2007, 11:06 PM I bought a vacuum gauge today. Vacuum readings taken at the brake booster vacuum hose port is 19" at idle and 20" at 2000 RPM. The needle is very steady. Goes to 0 and then up to 25" before resting at 19" when the throttle is snapped. The scanner still reads 10.7 though. I did try to clean it. It did not improve any. Is this an indication that the MAP sensor is bad? I have not checked the cam reference points yet. 5693dtcd 07-27-2007, 11:30 PM I have trim readings as follows ST Trim 1 121 ST Trim 1 % -5% LT Trim 1 120 LT Trim 1 % -6% ST Trim 2 120 ST Trim 2 % -6 LT Trim 2 120 LT Trim 2 % -6% At the risk of show what my lack of knowledge is - What do these reading show? I also question the MAP reading which is 10.7. There is another reading which is called BARO. This reading is 29" Hg. What is BARO? Thank you. MT-2500 07-28-2007, 10:24 AM Baro is the allitude from seal level. 29.0 is 1000 ft above seal level The Baro reading comes from Mass air flow sensor. MAP is engine vacuum. It comes from map sensor. It should read the engne vacuum. 18-20 HG no load on engine. Full load or thottle snap it will drop way down. If only reading 10 and actual engine vacuum is 18-20 range. Check vacuum to it and if ok check or replace MAP sensor. MT 5693dtcd 07-30-2007, 03:18 PM I installed new MAP sensor no change. I put gauge in same hole as sensor and read 19 Hg. I think I read the scanner tool wrong. The difference between the MAP readout and the MAF read out is 19. That is my vacuum. 5693dtcd 07-30-2007, 03:25 PM I installed a new distributor. No change in power but the cam retard is now 0 degrees. I found 2 timing hash marks on the balancer. At first I thought the timing was off one tooth. When I lined up the first mark the old dist. was off. I installed the new one dead on the referece point. Truck would not start!! Went back to other point and truck started. Cam retard is 0 but perfrmance is still poor. When a go into hard accel from stop the RPM maxs out at around 3000, vehicle speed is 40-45 with the engine misfiring, pinging and knocking. ADV is around 10-12. Knock sensor reading is fluctuating like it is trying to advance timing. If I accelerate gradually I eventually get to 55, the engine is quiet but is laboring. Timing is between 10-15 degrees. Help!!! 5693dtcd 08-01-2007, 01:28 AM Have you tried changing the mass air flow sensor? I've been doing a lot of reading and that may be my next step. The scanner I use indicates it is reading air but it may be sending a misleading signal to the ECM. Let me know if you have. Thanks. Calgary ZR2 08-01-2007, 01:55 AM After you try all that, I installed a OFF ROAD MSD with a MSD coil and MSD plug wires. This made a very larger noticable difference. I also use Royal Purple oil with a K&N oil filter. Believe it or not this oil works just as it claims. I have tried every highend oil and it is the only one where you can feel how smooth is runs and see yourself spending less on gas. I also use a Helix throttle body spacer with a K&N air filter. Have fun. Vern AJT1961 08-01-2007, 04:14 AM Have you tried changing the mass air flow sensor? I've been doing a lot of reading and that may be my next step. The scanner I use indicates it is reading air but it may be sending a misleading signal to the ECM. Let me know if you have. Thanks. No, mine is original, and has never thrown a code. 5693dtcd 08-01-2007, 10:25 AM No, mine is original, and has never thrown a code. Mine has not thrown a code either. I found the same symptoms on another website forum. I think he said his didn't code either. It had around 120,000 miles on it. I did try to clean it. No change. I'll keep this thread posted as to what I do next. 5693dtcd 08-01-2007, 09:17 PM Baro is the allitude from seal level. 29.0 is 1000 ft above seal level The Baro reading comes from Mass air flow sensor. MAP is engine vacuum. It comes from map sensor. It should read the engne vacuum. 18-20 HG no load on engine. Full load or thottle snap it will drop way down. If only reading 10 and actual engine vacuum is 18-20 range. Check vacuum to it and if ok check or replace MAP sensor. MT I think my next step is a MAF sensor. I read another forum with the same performance symptoms as mine. It checks out OK and doesn't throw a code. It reads 6.5 MHz at idle. My info says spec is 5-7. Will a MAF sensor cause the timing to retard? I also notice that during hard acceration it will only get up to about 35 MPH, one of the O2 sensors reads lean while the other reads rich. This does not change till I let off the accelerator and slowly get up to 55. When I do the O2 sensor fluxuate like they should. MT-2500 08-02-2007, 09:56 AM I think my next step is a MAF sensor. I read another forum with the same performance symptoms as mine. It checks out OK and doesn't throw a code. It reads 6.5 MHz at idle. My info says spec is 5-7. Will a MAF sensor cause the timing to retard? I also notice that during hard acceration it will only get up to about 35 MPH, one of the O2 sensors reads lean while the other reads rich. This does not change till I let off the accelerator and slowly get up to 55. When I do the O2 sensor fluxuate like they should. MAF does not change timing. It controls fuel mix. If fuel mix is off the scanner will read heavy + or - on long terms fuel trims. What is long and short term fuel mix? 5693dtcd 08-02-2007, 02:05 PM MAF does not change timing. It controls fuel mix. If fuel mix is off the scanner will read heavy + or - on long terms fuel trims. What is long and short term fuel mix? Thank you for responding Readings are as follows ST trim 1 fluxuates between 126-129. The % fluxuates between 0 and -2% LT Trim 1 reads a steady 112 with the % at -12 and holding ST trim 2 fluxuates between 127-129 with the % between -1 - +2% LT Trim 2 reads a steady 113 with the % at 12% and holding. My check engine light came on yesterday. I checked the codes this morning I have p0300 Misfire p0101 Mass air out of range p0143 p0131 I accidently cleared the codes before reading what the last 2 meant. Does the P0101 indicate I have a bad MAF sensor? Thank you Thanks for your help. 5693dtcd 08-07-2007, 06:53 PM MAF does not change timing. It controls fuel mix. If fuel mix is off the scanner will read heavy + or - on long terms fuel trims. What is long and short term fuel mix? I threw a code today coming home. P0101 Mass Air circuit out of range. I did a freeze frame on the scanner and received the following readings Eng. load 25% Coolant 149 ST Trim 185 ST trim % 44.5 LT Trim 138 LT Trim % 7.8 ST Trim 2 % -24.2 LT Trim 2 % 0 MAP 29.3 RPM 2306 Veh spd 52 mph MAF gm/sec 43.68 TPS 59% I was tryng to accelerate. Engine was runninig very rough with very little power. Do any of these readings help in telling what is wrong. I have not tried a MAF sensor yet. Since it has a code now I'm thinking that this may be the problem. It still does not explain why the timing changes. sheadogsavannah 08-10-2007, 12:00 PM I too have the same sluggish acceleration problem along with low MPG. At least in my opinion it is low MPG. This is a new vehicle to me so I only have one average MPG reading based on a half tank of gas - 14.5 MPG. However, to be fair this is based on city driving, in sweltering heat 90 to 100 degrees, with the auto temp set at 78. Is 14.5 MPG normal under those conditions? We just put $1800 into general maintenance repairs that included new spark plugs and wires, fuel filter and alignment with tire rotation and balance. We also made some other maintenance repairs, but they would not have any affect on sluggish acceleration or MPG. I have read the other posts but I have no computer readings to compare the performance. There are no codes showing or trouble lights on that would indicate that there is a problem. Is this poor performance or normal for the 2000 Bravada? MT-2500 08-10-2007, 12:45 PM I too have the same sluggish acceleration problem along with low MPG. At least in my opinion it is low MPG. This is a new vehicle to me so I only have one average MPG reading based on a half tank of gas - 14.5 MPG. However, to be fair this is based on city driving, in sweltering heat 90 to 100 degrees, with the auto temp set at 78. Is 14.5 MPG normal under those conditions? We just put $1800 into general maintenance repairs that included new spark plugs and wires, fuel filter and alignment with tire rotation and balance. We also made some other maintenance repairs, but they would not have any affect on sluggish acceleration or MPG. I have read the other posts but I have no computer readings to compare the performance. There are no codes showing or trouble lights on that would indicate that there is a problem. Is this poor performance or normal for the 2000 Bravada? Welcome to AF If you have a problem on yours it is best to start a new thread and some one will help. Two different problems on on post gets confusing.:grinyes: http://www.automotiveforums.com/vbulletin/showthread.php?p=4820845#post4820845 http://www.automotiveforums.com/vbulletin/newthread.php?do=newthread&f=2072 But I would check it on a long highway drive to get a good idea of the actual fuel mileage. And go by how many gallons it takes to fill it back up after starting with a full tank. Just gauge reading is not a very good way to judge mileage. MT 5693dtcd 08-10-2007, 08:34 PM I too have the same sluggish acceleration problem along with low MPG. At least in my opinion it is low MPG. This is a new vehicle to me so I only have one average MPG reading based on a half tank of gas - 14.5 MPG. However, to be fair this is based on city driving, in sweltering heat 90 to 100 degrees, with the auto temp set at 78. Is 14.5 MPG normal under those conditions? We just put $1800 into general maintenance repairs that included new spark plugs and wires, fuel filter and alignment with tire rotation and balance. We also made some other maintenance repairs, but they would not have any affect on sluggish acceleration or MPG. I have read the other posts but I have no computer readings to compare the performance. There are no codes showing or trouble lights on that would indicate that there is a problem. Is this poor performance or normal for the 2000 Bravada? I'm new here too. The problem I am having is bad enough that the vehicle is nearly unsafe to drive. When I put the pedal to the floor it will not speed up. I have to very gradually accelerate. I drive like the is an egg on the pedal. Now I know I shouldn't floor it every time I go somewhere. The engine is not creating any power though. The best mileage I got was on a long interstate run. It can get up to around 20-22 depending on how fast and how loaded. That was when everything was working good. Keep reading you may see some other ideas. old_master 08-10-2007, 08:59 PM K&N air filters are a known problem when used on vehicles with MAF sensors. The MAF sensor uses two "wires" and a heated wire for sensing purposes. The oil from the air filter coats the "wires" in the MAF sensor causing incorrect readings. Carefully clean the sensor "wires" with a spray type brake cleaning solvent. Brake cleaner leaves no residue, carb cleaner does. Have you checked fuel pressure and leakdown? 5693dtcd 08-11-2007, 12:24 AM K&N air filters are a known problem when used on vehicles with MAF sensors. The MAF sensor uses two "wires" and a heated wire for sensing purposes. The oil from the air filter coats the "wires" in the MAF sensor causing incorrect readings. Carefully clean the sensor "wires" with a spray type brake cleaning solvent. Brake cleaner leaves no residue, carb cleaner does. Have you checked fuel pressure and leakdown? Yes fuel pressure is good, it runs 60-65 psi. I do not have a K&N filter. I have replace the fuel pressure module, fuel pump, and filter. I have also tried cleaning the MAF wires. All of this has not improved my problem. As stated earlier the timing seems to be the main issue. At idle it is 20 degrees BTDC. At 3000 rmp it is 10 degrees. AJT1961 08-11-2007, 05:26 AM Sorry to hear you haven't found your problem yet. My thoughts keep going back to what I mentioned about my 2000 Blazer in my response to your original post: "I ran a quart of block flushing solvent in the crankcase for the recommended number of minutes, drained it and put in fresh oil and filter. During the test drive, it rode like I had installed a supercharger on the vehicle -- the increase in power was beyond incredible -- it seemed even better than when I bought it new. After that, the power gradually decreased over a few hundred miles and went back to "normal" since then, which was over a year ago. I've always changed the oil and filter every 3000 miles from new, so I assumed it was not a general sludge problem. I don't know what any of this means (is there some offending senser that the block flush temporarily cleaned?), or whether it could be related to the problem you are having." If you are willing to take the risk (as I did) of using block flush in a high mileage engine (I did it because some coolant had leaked into my crankcase from the bad lower intake gasket), it would be interesting to see if you experience the same dramatic, albeit temporary, power boost that I experienced. Of course, if it does drastically improve your power as it did mine, it still doesn't exactly explain the cause of the problem. As a side note, I have never used a K&N air filter either -- my Blazer has been 100% stock from new and has always been properly maintained on or ahead of schedule. I don't remember the particular brand of flush I used, but I bought it at Autozone and it was in an old-fashioned 1 quart metal oil can -- the kind they sold oil in before they came out with plastic bottles with screw-off caps. Good luck. MT-2500 08-11-2007, 10:01 AM Yes fuel pressure is good, it runs 60-65 psi. I do not have a K&N filter. I have replace the fuel pressure module, fuel pump, and filter. I have also tried cleaning the MAF wires. All of this has not improved my problem. As stated earlier the timing seems to be the main issue. At idle it is 20 degrees BTDC. At 3000 rmp it is 10 degrees. Timing is not adjustable. The VCM controls timing. Did you ever get the camshaft retard setting set right. What is it reading? 5693dtcd 08-11-2007, 11:08 AM Timing is not adjustable. The VCM controls timing. Did you ever get the camshaft retard setting set right. What is it reading? Yes, I replaced the distributor with a new cam position sensor. The cam retard reading is now 0 degrees. There where 2 marks on the harmonic balancer. I have marked the one with paint, that gives me the reading of 0 cam retard. The fuel trim readings are in previous replies if you still need that info. thank you. 5693dtcd 08-11-2007, 11:10 AM Sorry to hear you haven't found your problem yet. My thoughts keep going back to what I mentioned about my 2000 Blazer in my response to your original post: "I ran a quart of block flushing solvent in the crankcase for the recommended number of minutes, drained it and put in fresh oil and filter. During the test drive, it rode like I had installed a supercharger on the vehicle -- the increase in power was beyond incredible -- it seemed even better than when I bought it new. After that, the power gradually decreased over a few hundred miles and went back to "normal" since then, which was over a year ago. I've always changed the oil and filter every 3000 miles from new, so I assumed it was not a general sludge problem. I don't know what any of this means (is there some offending senser that the block flush temporarily cleaned?), or whether it could be related to the problem you are having." If you are willing to take the risk (as I did) of using block flush in a high mileage engine (I did it because some coolant had leaked into my crankcase from the bad lower intake gasket), it would be interesting to see if you experience the same dramatic, albeit temporary, power boost that I experienced. Of course, if it does drastically improve your power as it did mine, it still doesn't exactly explain the cause of the problem. As a side note, I have never used a K&N air filter either -- my Blazer has been 100% stock from new and has always been properly maintained on or ahead of schedule. I don't remember the particular brand of flush I used, but I bought it at Autozone and it was in an old-fashioned 1 quart metal oil can -- the kind they sold oil in before they came out with plastic bottles with screw-off caps. Good luck. I have seen oil flush before. I'm not due for an oil change for awhile but I may try it. I have nothing to loose. Thanks and keep reading this thread. MT-2500 08-11-2007, 11:18 AM Yes, I replaced the distributor with a new cam position sensor. The cam retard reading is now 0 degrees. There where 2 marks on the harmonic balancer. I have marked the one with paint, that gives me the reading of 0 cam retard. The fuel trim readings are in previous replies if you still need that info. thank you. The cam retard has to be set with a good engine capable scanner. The timing marks on crank has nothing to do with camshaft retard. Camshaft retard is the position the rotor fires the plugs wires. Say no to a engine flush pitch it in the trash can. Many engine have been killed with engine flush crap.:grinyes: MT 5693dtcd 08-11-2007, 08:45 PM The cam retard has to be set with a good engine capable scanner. The timing marks on crank has nothing to do with camshaft retard. Camshaft retard is the position the rotor fires the plugs wires. Say no to a engine flush pitch it in the trash can. Many engine have been killed with engine flush crap.:grinyes: MT I was useing the marks on the balancer to determine where TDC was and check the reference point of the distributor. You had indicated in an earlier post were the rotor should be pointing. I had lined up the mark on the balance with the notch in the timing cover. At first the rotor was not correct. When I moved it to correct it- the engine would not start. Thats when I found two marks. I went ahead and installed a rebuilt distributor. The screw holes for the cap holddown were stripped out. I lined it up with the mark that I thought was correct. The engine started right up and the cam retard readout was 0. I do not know how cam shaft retard is set with the scanner. If it is currently reading 0 it should be OK. Right? thank you. MT-2500 08-12-2007, 09:28 AM The actual engine timing is set and controlled by the crankshaft senor and VCM. The engine timing is not adjustable. Setting the dist or camshaft retard is the pointing the rotor to fire direct on the plug wire terminal. Camshaft retard is not checked or set with a timing light or timing marks. You need a good engine capable scanner that will read out the camshaft retard. It will read out it in - or + degrees and only updates the reading with engine running over 1K rpm. Turn the dist so the camshaft retard setting in the scanner reads as close to zero degrees as you can get it or 1-2 degrees - or +. If the setting is over 3 degrees off it can give some engine running problems and even misfire. If rotor is not centered on plug wire it will also increase spark and burn plugs and wire from hot spark and long term piston melt down. Some are a pain to set as some dist are not adjustable and some rebuilt dist gears are put on a half turn off. 5693dtcd 08-13-2007, 12:04 AM The cam retard has to be set with a good engine capable scanner. The timing marks on crank has nothing to do with camshaft retard. Camshaft retard is the position the rotor fires the plugs wires. Say no to a engine flush pitch it in the trash can. Many engine have been killed with engine flush crap.:grinyes: MT I'm a little confused. I used the marks on the balancer as a reference to install the new distributor. The cam retard now reads 0 degrees on the scanner. Does it still need to be set? I was borrowing a Snap-On scanner. I am unsure of the model but it would do everything you needed it to. Are the fuel trim readings I posted out of spec? Thank you. MT-2500 08-13-2007, 10:02 AM I'm a little confused. I used the marks on the balancer as a reference to install the new distributor. The cam retard now reads 0 degrees on the scanner. Does it still need to be set? I was borrowing a Snap-On scanner. I am unsure of the model but it would do everything you needed it to. Are the fuel trim readings I posted out of spec? Thank you. If it reads 0 degrees on a scanner you are set to go. Right on the money. Clear codes and drive and recheck the fuel trims and for any codes coming back. The lower the fuel trims the better. Post back after re driving. MT 5693dtcd 08-13-2007, 12:11 PM If it reads 0 degrees on a scanner you are set to go. Right on the money. Clear codes and drive and recheck the fuel trims and for any codes coming back. The lower the fuel trims the better. Post back after re driving. MT I have cleared the codes. What would lower trim codes read. I do not know what would be considered high. Are these readings high? Readings are as follows ST trim 1 fluxuates between 126-129. The % fluxuates between 0 and -2% LT Trim 1 reads a steady 112 with the % at -12 and holding ST trim 2 fluxuates between 127-129 with the % between -1 - +2% LT Trim 2 reads a steady 113 with the % at 12% and holding. Truck still has no power and the timing is still retarding to around 10 degrees at 3000 RPM. In a previous post , after I installed the new distributor, I recorded a MAF sensor code. If these fuel trim readings are out of spec, should I change the MAF sensor? I have already tried cleaning it. I may try 1 more time though. Thank you for your input. MT-2500 08-13-2007, 12:43 PM I have cleared the codes. What would lower trim codes read. I do not know what would be considered high. Are these readings high? Readings are as follows ST trim 1 fluxuates between 126-129. The % fluxuates between 0 and -2% LT Trim 1 reads a steady 112 with the % at -12 and holding ST trim 2 fluxuates between 127-129 with the % between -1 - +2% LT Trim 2 reads a steady 113 with the % at 12% and holding. Truck still has no power and the timing is still retarding to around 10 degrees at 3000 RPM. In a previous post , after I installed the new distributor, I recorded a MAF sensor code. If these fuel trim readings are out of spec, should I change the MAF sensor? I have already tried cleaning it. I may try 1 more time though. Thank you for your input. Fuel trims is way off. If one side is way + and other side is way -. One side is rich and one side is way lean. MT burnchassis3 08-13-2007, 04:05 PM I been here before! My problem was the MAF. id floor the truck ,and it felt like i was pulling a house not on wheels. to check it: unplug the MAF and drive,if the MAF is bad you will feel the HUGE power gain,if the MAF isnt bad you wont feel any difference. Unplug it and go for a ride.:smokin: CS sheadogsavannah 08-13-2007, 05:02 PM Please forgive my ignorance, but what is the MAF, where is it, and how do I unhook it? burnchassis3 08-13-2007, 05:29 PM MASS AIR FLOW METER or SENSOR. Its called both.... Its located just behind the air box on the air intake hose 1 clip 3 wires. There should be 2 sets of wires 1 has 2 wires the other has 3. CS sheadogsavannah 08-13-2007, 06:35 PM Thanks so much, it did seem to increase the power. Since disconnecting the MAF my check engine soon light has come on. I have reconnected the MAF, but can't get the light to go off. How do I reset it? burnchassis3 08-13-2007, 06:49 PM Thanks so much, it did seem to increase the power. Since disconnecting the MAF my check engine soon light has come on. I have reconnected the MAF, but can't get the light to go off. How do I reset it? you can pull the + battery cable for a few minutes,that will reset the computer. I ran with my light on for ages. Glad it helped 5693dtcd 08-14-2007, 10:23 PM I been here before! My problem was the MAF. id floor the truck ,and it felt like i was pulling a house not on wheels. to check it: unplug the MAF and drive,if the MAF is bad you will feel the HUGE power gain,if the MAF isnt bad you wont feel any difference. Unplug it and go for a ride.:smokin: CS I have tried unplugging the MAF sensor. I gain RPMs and that is it. I do not get any more HP. On the shop floor no load with sensor plugged in, I get about 3500 rpm. Unplugged it will redline. Take it out on the road it still struggles to get up to and maintain 55 MPH. The only difference I see is that the tranny shifts harder. The engine is not creating any torque. If you read previous post, the timing retards back to around 10 degrees at 3000 RPM. It should be advancing. I'm beginning to think I have two items causing this problem. Keep reading and I will post more results as I get them. 5693dtcd 08-14-2007, 10:29 PM Thanks so much, it did seem to increase the power. Since disconnecting the MAF my check engine soon light has come on. I have reconnected the MAF, but can't get the light to go off. How do I reset it? I have read other post where owners have cleaned the MAF sensor. You have to remove the component and use a cleaning solvent that you can buy at a parts store. Tell them what you are trying to clean so that you will get the right stuff. There are 3 wires inside the air tube of the MAF sensor. They are very fragile- but you should be able to spray the wires and improve your performance, if they are dirty. After 100,000 miles they may have a film on them. They are VERY sensitive to dirt. Good luck. 5693dtcd 08-16-2007, 01:42 AM Fuel trims is way off. If one side is way + and other side is way -. One side is rich and one side is way lean. MT Ok- It would appear then I also have a fuel problem along with a timining problem. Does the MAF sensor affect fuel trim? If not what does? Could it be the VCM throwing in the wrong amount of fuel of have I got bad injectors? If the fuel mixture is off, could it affect another sensor, which would tell the VCM to retard the timing? From reading the other post would you agree that changing out the MAF sensor might be a good place to start? I have tried cleaning it and it does not help. If I unplug it, I gain in RPM on the shop floor with no load. On the test drive though it still has very poor performance and low power. The transmission seems to shift harder also. It would appear to me I may have to replace either a MAF sensor, the injectors, a VCM or possibly a crank position sensor. Do you think I might be on the right track? Thank you. MT-2500 08-16-2007, 09:28 AM Ok- It would appear then I also have a fuel problem along with a timining problem. Does the MAF sensor affect fuel trim? If not what does? Could it be the VCM throwing in the wrong amount of fuel of have I got bad injectors? If the fuel mixture is off, could it affect another sensor, which would tell the VCM to retard the timing? From reading the other post would you agree that changing out the MAF sensor might be a good place to start? I have tried cleaning it and it does not help. If I unplug it, I gain in RPM on the shop floor with no load. On the test drive though it still has very poor performance and low power. The transmission seems to shift harder also. It would appear to me I may have to replace either a MAF sensor, the injectors, a VCM or possibly a crank position sensor. Do you think I might be on the right track? Thank you. Uneven fuel trim leads to problems with one side rich or lean. Maf sensor should make both side high or low. Run a cylinder balance or injector balance test. nitrostreet 08-18-2007, 06:32 PM I have had it hooked up to a Snap On computer. All the sensors appear to be doing what they are supposed to. The problem is in the timing. At idle it is 20 BTDC. Try to throttle up and it starts to advance but when the engine hits around 3000 rpm the timing retards to less than 10. The timing is not advancing like it should. The knock sensor and MAP sensors are both creating the proper voltage signal to the ECM. Shop floor no load RPM's rarely get over 3500. When they do the timing is not retarding as far. What else can affect timing? This is my first posting. I have been able to try other ideas that I have seen posted here on this web sight. Thank you for reading. I’ve read your problem and replies to your problem and I’m going to try to put in my 2 cents from my drag racing days. When you say that your cam was retarded 10 degrees and now it’s close to zero in your other replies are you talking about your actual crank to camshaft timing, or are you talking about your ignition timing? I have to ask that because I’m not aware of any way to change the crank to camshaft timing without pulling the timing chain and either getting an offset crank key or triple-keyed crank sprocket. Assuming that you are referring to ignition timing, if you are only getting 10 degrees total timing above 3000 RPM I don’t see how your motor could pull above 3500 RPM. I can take my drag race motor which can normally see 7000 to 8000 rpm and set the total timing to 10 degrees and it will not wing past 3500 RPM either. (Normally most naturally aspirated motors like somewhere in the neighborhood of 38 degrees of total timing from 3000 rpm and up, retarding a few degrees as you start getting above 6000 rpm or so) I hooked my scanner up to my ’98 Chevy Blazer (which has pretty decent acceleration and mileage) and took it down the highway to see what kind of timing it was getting and it would go all the way up to 41 degrees total timing on the long flat stretches of highway backing down to 20 or so timing when it starts going up a grade. If there’s no factory way to fix the timing you may need to look into an aftermarket performance programmer similar to the Jet – 15015 programmers available through places like Summit Racing as well as your local auto parts store, you can set different timing curves among other things with that. Again I’m not saying that this is your only problem, but I could probably make most motors run with similar characteristics to yours (computer controlled or not) by simply backing the total timing down to 10 degrees, so if it was my motor that’s the first thing I would be worried about. 5693dtcd 08-19-2007, 04:34 PM I’ve read your problem and replies to your problem and I’m going to try to put in my 2 cents from my drag racing days. When you say that your cam was retarded 10 degrees and now it’s close to zero in your other replies are you talking about your actual crank to camshaft timing, or are you talking about your ignition timing? I have to ask that because I’m not aware of any way to change the crank to camshaft timing without pulling the timing chain and either getting an offset crank key or triple-keyed crank sprocket. Assuming that you are referring to ignition timing, if you are only getting 10 degrees total timing above 3000 RPM I don’t see how your motor could pull above 3500 RPM. I can take my drag race motor which can normally see 7000 to 8000 rpm and set the total timing to 10 degrees and it will not wing past 3500 RPM either. (Normally most naturally aspirated motors like somewhere in the neighborhood of 38 degrees of total timing from 3000 rpm and up, retarding a few degrees as you start getting above 6000 rpm or so) I hooked my scanner up to my ’98 Chevy Blazer (which has pretty decent acceleration and mileage) and took it down the highway to see what kind of timing it was getting and it would go all the way up to 41 degrees total timing on the long flat stretches of highway backing down to 20 or so timing when it starts going up a grade. If there’s no factory way to fix the timing you may need to look into an aftermarket performance programmer similar to the Jet – 15015 programmers available through places like Summit Racing as well as your local auto parts store, you can set different timing curves among other things with that. Again I’m not saying that this is your only problem, but I could probably make most motors run with similar characteristics to yours (computer controlled or not) by simply backing the total timing down to 10 degrees, so if it was my motor that’s the first thing I would be worried about. Thanks for your response. I do not fully understand cam retard. It has to do with the cam postion sensor in the distributor. It "reads" how musch wear is on the chain, telling the ECM where the cam is. Then the ECM can adjust ignition timining if needed. The performance of where my cam retard used to be VS being a 0 now is no difference. The ignition timing is where I have the problem. I have to find out why my timing goes to 10 degrees at 3500. It is not creating power at all. Everything I have left to try is too expensive to just "try it and see". I think it will be one of the following, ECM, injectors, or a MAF sensor. MT-2500 suggested a injector balance test. I hope to be able to do that soon. I borrowed the scanner I had and took it back. Keep reading I hope to solve this soon. nitrostreet 08-19-2007, 09:20 PM The ignition timing is where I have the problem. I have to find out why my timing goes to 10 degrees at 3500. It is not creating power at all. Everything I have left to try is too expensive to just "try it and see". I think it will be one of the following, ECM, injectors, or a MAF sensor. MT-2500 suggested a injector balance test. I hope to be able to do that soon. I borrowed the scanner I had and took it back. Keep reading I hope to solve this soon. The Injector balance test is a good idea also, if you've got a dead or weak cylinder that could also be the problem. I noticed that AJT1961 in his reply noted that his 2000 Blazer was also low on power and he noticed a few other posts from other people with 2000 Blazers with the same "low power" problem and that's what got me to wondering if for some reason GM has a glitch in the 2000 programs for the Blazers that doesn't control the timing like it should. It would be interesting if maybe another thread could be started and see if the other people with the low power 2000's (or any other years) could moniter their timing curves and post what they're seeing on the scanners as they drive down the highway or around town. kb3jhp 08-20-2007, 04:49 PM the cam timing is fine the -number comes from dist gear wear. the cam position sensor is in the dist so it tells the comp that the cam and crank is out of time when the dist gear is at fault. With it being out by just 11 a new gear should bring it close to 0 gm allows -2to +3 if it is to far out it can cause arcing in the cap because the coil will fire before it reaches the post in the dist cap. which can cause cross fire and this making the engine miss the comp only reads the timing when the rpms are raised above 2400rpm I think its 2400 need_a_new_truck 08-20-2007, 08:45 PM Check the ignition control module. 5693dtcd 08-21-2007, 12:04 AM the cam timing is fine the -number comes from dist gear wear. the cam position sensor is in the dist so it tells the comp that the cam and crank is out of time when the dist gear is at fault. With it being out by just 11 a new gear should bring it close to 0 gm allows -2to +3 if it is to far out it can cause arcing in the cap because the coil will fire before it reaches the post in the dist cap. which can cause cross fire and this making the engine miss the comp only reads the timing when the rpms are raised above 2400rpm I think its 2400 Thank you for the explanation. Automotive Network, Inc., Copyright ©2012
