Need Help-Steering issue
twistedone
11-07-2002, 07:05 PM
On lower speeds (0-10mph) with my 92 EX 2 dr when i turn steering wheel i get squeaky noise that seems to be coming from steering rod area. At higher speeds when making turns it is not preent. The power steerinf fluid level is good and i have not noticed any leaks whatsoever
What are possible causes and if anyone has experienced any such problems then what will the damange to the check book be???
Also when is factory recommendation for changing shocks/springs and timing belt.
Thx
twistedone
11-07-2002, 07:06 PM
ps . sorry for the dang typos
pimpstyles77
11-15-2002, 09:13 PM
CHECK YOUR CB BOOT, IT CAN BE FUCKED UP AND YOU HEARING THE AXEL RUB AGAINST IT
w00ters
11-21-2002, 01:51 AM
60,000 its factory t-belt replacement, they will replace water pump at this time too...
as for your noise, somthing is rubbing, i ve seen things stuck in there or a boot is about to blow
