Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 07-20-2007, 01:19 PM   #1
Paul09876
Paul09876 Normal reputation
95 Astro engine temp reads low
Hi, my 95 Astro temp gauge reads about 160 under most operating conditions. I just pulled the thermostat and boiled it in water, opening at the correct 195 degrees. To check to make sure the temp sensor was working I drained some coolant and ran it until the gauge went all the way to the red zone. Still may be the sensor, don't have a ohm/temp chart to check it. Before I buy a new one could it be something else-gauge/wiring? The sensor only has one wire, was it later they went to the 5v reference sensor? Is the low gauge reading making it run rich? Thanks!
Paul09876 is offline   Reply With Quote
Old 07-21-2007, 05:38 PM   #2
ericn1300
AF Premium User
ericn1300's Avatar
ericn1300 Normal reputation
Re: 95 Astro engine temp reads low
Ouch, that was kinda severe since a sender is under $10. replace the thermostat, temp sender and radiator cap all at once, probably around $25 total,and at that age they all need replacing any way, and see what happens. my bet is the rad cap isn't holding pressure anymore.
ericn1300 is offline   Reply With Quote
Old 07-25-2007, 08:53 PM   #3
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
Your 95 Astro has 2 temp sensors: one for the computer, (intake manifold near the thermostat) and one for the gauge, (left cylinder head between plugs 3 & 5). I believe 98 was the first year that only one sensor was used for both PCM and gauge. Class 2 communications are used to send data to the temp gauge in the dash. If the engine is in fact running cold, the PCM will richen the fuel mixture and cause a drop in fuel mileage. Eric's suggestion will most likely take care of the problem.
old_master is offline   Reply With Quote
Bookmarks
Google
Web AF
