2001 Yukon XL ABS light coming on
buem
07-19-2007, 09:37 PM
2001 GMC Yukon XL 1/2 Ton-2WD
5300 V8- (mileage 128,000)
My ABS light came on when I started the car today. When I turned off the ignition, the module continues to humming non-stop. I pulled the 60 amp fuse and it stopped humming (brake warning light then comes on ONLY when I pull this fuse). I put the fuse back in and naturally it started humming again (brake warning light goes off as well). Is there a relay? And if so, where can I locate it to see if that is the problem. Otherwise, what can I do to rectify this situation cost effectively.
**I have found that the abs module needs to be replaced or refurbished and saw that CircuitSolutions.com can handle this, but is there another company that can do this locally. I am in Raleigh, NC. Anywhere significantly closer that Idaho?
2000CAYukon
07-20-2007, 02:06 PM
Looking at my bookmarks, the other place that I know of that repairs the module is http://www.absfixer.com/
//2000CAYukon
bcopeland
07-20-2007, 08:40 PM
I used circuit solutions in Idaho about as far from NC as Texas. It took 1 week to 10 days turn-around. You can drive with the fuse pulled. You only drive without ABS, which is what I did for about the first 20 years of my life anyways.
