Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 07-18-2007, 02:48 PM   #1
Ourgang07
Ourgang07 Normal reputation
Problem with charging system in Astro 4.3
Hi,
I have a 1999 Astro 4.3 Litre. The amp meter reads 14 volts until I put on some accessories such as the ac or wipers. The volt reading drops down very low (11volts) with the load placed on the system. I removed a battery cable with the van running and the engine continues to run which is confusing me because usually when a car is not charging it will cut off with the cable removed.. I feel that the alternator is bad but wanted another opinion. I tried a different battery in the van and had the same problem. Thanks in advance for any help.
Take care,
John
Ourgang07 is offline   Reply With Quote
Old 07-19-2007, 08:31 AM   #2
brcidd
brcidd's Avatar
brcidd Normal reputation
Re: Problem with charging system in Astro 4.3
voltage drop is no good- the engine will run with very low voltage- it is one of the least current draws on your vehicle- remove the alternator- have it checked- I have a rebuilder rebuild the bearings, diodes etc- usually for $60
Automotive A/C Engineer with:
'95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone- blown head gasket
'92 Chevy Lumina Van 3.8L 264k miles
'86 GMC S-15 - 2.8L 154k miles
'86 Buick Park Ave 3.8L 199k miles- my daily driver
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles- my high school car!!
All but the Camaro and Firebird are white....
brcidd is offline   Reply With Quote
Old 07-25-2007, 07:38 PM   #3
boatbuster
boatbuster Normal reputation
most alternator rebuilding shops will test your alternator for free. So will some auto parts stores. I would have the alternator tested prior to removing it from the van and then go from there -> alternator or battery. Just because the alternator gives you 14 volts does not mean that it is pumping out the amps it should and that might be where your problem is.
boatbuster is offline   Reply With Quote
Old 07-26-2007, 07:11 PM   #4
Ourgang07
I thought for sure it would be the alternator after I switched the battery and that didn't fix it. I just replaced the alternator and have the same problem. When I first start the van it is putting out a bit over 14 volts. When I put on the ac, rear ac, and radio, the gauge drops to about 11 volts. It is charging, but the volts are low. Any ideas? Thanks,
John
Old 07-26-2007, 07:24 PM   #5
boatbuster
check your battery. sounds like you have a bad battery. the alternator can not keep up with the demand of the battery sucking up juice and the accessories.
Old 07-26-2007, 07:34 PM   #6
Ourgang07
Thanks for the response. I already replaced the battery with one from my other car and had the same problem. That was when I figured it had to be a bad alternator. Now that I tried both I'm not sure what's left? Thanks,
John
Old 08-04-2007, 09:12 PM   #7
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
Check the battery cable connections, both ends of both cables, for corrosion. They need to be shiny clean and tight. Inspect the entire length of the cables for cuts in the insulation where moisture can enter and cause corrosion. Also check the connections and insulation on the red 10ga wire from the back of the alternator to the battery. The battery needs to have the correct capacity and reserve. The alternator maximum output should be checked. Just because it's new doesn't mean it's good, ever buy a new car and have something go wrong? Hope this helps
old_master is offline   Reply With Quote
Bookmarks
Google
Web AF
