Burning too much petrol?!!crocklip 07-18-2007, 07:33 AM Hi, I recently bought a Nissan Almera GX 1996. I have noticed that the KM per litre is surprising low (About 3KM/Litre!!!) There is a strong smell of petrol (outside) after running. Th engine also 'Sputters' sometimes! Pleases help ana amateur! Thanks INF3RN0666 07-18-2007, 09:41 AM Bro, it sounds like you aren't getting full combustion. If you know how long ago they replaced the plugs and wires, I would do that first. If the problem doesn't go away, you might have an ignition problem and could be due to Coils, ECM, or other things that I don't know about. At least you know that your injectors are working :P. vgames33 07-18-2007, 12:57 PM That has the GA16DE engine, correct? From what I've seen, they are very well built. If your ignition is good (plugs, wires, cap, rotor, etc), I'd look for a bad injector (stuck open), or a blown pressure regulator. Is the check engine light on? KiwiBacon 07-19-2007, 02:34 AM Get the MAF sensor and exhaust oxygen sensors checked. A mate had his nissan V6 running at 7:1 (lambda = 2) with a screwed up O2 sensor. Most engines would have fouled up long before then. Automotive Network, Inc., Copyright ©2012
