sunroof leaking(rear drain holes)cassie94 07-17-2007, 12:02 AM are rear drain holes accessible on 2002 expedition? The rear drivers side drain appears to be clogged but I don't know how to get to it. Any info would be appreciated. Thanks rivguy 07-26-2007, 10:20 PM remove the seal from the rear door, grab handle and c pillar trim (required seat belt anchor nut removed) then you can pull the headliner down far enough to pull the hose loose and clean. Automotive Network, Inc., Copyright ©2012
