starts up hard after runningjeff urquhart 07-15-2007, 11:22 PM I have a 4 cldr that starts up hard after running? in the morning it starts fine and after warming up its fine any ideas jeff urquhart 07-15-2007, 11:24 PM white smoke also than disapates and runs fine? xeroinfinity 07-15-2007, 11:29 PM That was the non tech forum you posted in so I moved them for you. Welcome to AF. What year, engine, mileage??? jeff urquhart 07-15-2007, 11:36 PM 98 2.4 4cyl 120000 evap code registers hopfully a choke sensor?? or somthing? if it was a head gasket it should act diff. or maybe it needs to warm to act up. no water in oil or fuel in oil! xeroinfinity 07-15-2007, 11:48 PM I have a 4 cldr that starts up hard after running? in the morning it starts fine and after warming up its fine any ideas Ok first that does not make sense... If it starts cold(in the morning) and after warming up... whats the problem then :cinfused: The hard starts when its hot could be a bad engine ground, loose connections on th engine ignition system, faulty emission syst. Get it scanned! That will tell you a lot. White smoke could be steam, do a compression test to see if any cylinders are low . good luck Automotive Network, Inc., Copyright ©2012
