94 Montero won't start / blown fuseaudiparty 07-13-2007, 08:48 PM Hello, I'm new to the community. Just bought a 94 Montero from an individual and it ran for about 2 weeks then stopped working one day. So, i took it into a mechanic and $600.00 later....i'm having the same problem 2 weeks later. Mechanic told me the fuse was blown, and I should just replace it if it happens again. We'll...easier said then done, because it ate up 4 more fuse's without starting. It's the green one under the hood..and idea what could be causing this? Thanks..avoiding the shop ..and another bill mxmikie 10-08-2007, 02:22 AM what is the fuse for ???????????? solarone 10-12-2007, 12:58 PM This is probably the starter fuse. Fuses usually blow (always) because of excess current flow, so you most likely have a shorted starter motor or the + starter lead is shorted to the chassis (-). vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
