neutral safety switchnamylg 11-05-2002, 03:53 PM My Jeep had problems starting in park so I would start it in neutral. Then the problem got worse and now it will only start when the Jeep is cold. If I drive it 1/2 hour or so it won't start again unless I let it cool down for a couple of hours. I have taken apart the neutral safety switch and cleaned it. I have also replaced it with one from a junkyard and that still did not correct the problem. Any ideas? Thanks. jlynch 12-13-2003, 07:21 PM I am having the same problem with my 89 Jeep Cherokee. If you find out what the problem is please let me know. Thank you richpinkham 12-13-2003, 11:43 PM check the ignition switch on the steering colume under the dash. I had to replace mine twice already in 70,000 miles. carguyinok 12-14-2003, 12:06 AM check the ignition switch on the steering colume under the dash. I had to replace mine twice already in 70,000 miles. :iagree: I had the same thing with mine left me like :cya: It can be a real pain to replace, so set aside some time for the job. jlynch 12-14-2003, 04:58 PM I have changed the ignition switch in my 89 cherokee. If I start it when it is cold it will start right up, but after I drive it for a half hour or so and turn it off it will not start back up. When I turn the key it does nothing no clicking or noises of any kind. After it sits for a little while it will start right up. Any more suggestions? Thanks in advance jlynch 12-16-2003, 09:00 PM I took my nss off the jeep. Took it apart and cleaned it and greased it, seems to have fixed the problem. Automotive Network, Inc., Copyright ©2012
