Thermostat on 2000 GA with 2.4
SnipesXxX
07-12-2007, 02:31 PM
I read on here where its located but not quite understanding it. Does anyone have any pics of where its located? I am wondering if I can change it using ramps and not having to take it to the shop. Is it a PITA to change without a lift?
The shop is wanting roughly $180 for a coolant flush and thermostat change. I'd like to save $100-$120 by doing the job myself if its not a huge hassle.
Jmoney3318
07-12-2007, 02:49 PM
im so not gunna lie i dont kno how the engine is put together so i cant really help you all i kno is i put the enw thermostat on the 3.4l and had to put new coolant in, its pretty simple a pain in the ass to get to but in the end like you said u dont wanna spend 180 bux to get it changed...ill see if i can find any sources before Xero or any1 helps u before i do
xeroinfinity
07-12-2007, 09:58 PM
Yes the thermostat is barried under the pass side of the engine.
If you can get it onto ramps without hitting you front bumper you might be able to get to it.
Thier are two nuts on either side of the thermostat housing, you will need a longer extension for this.
And thier should be on bolt/nut holding the pipe to the oil pan. Pretty sure both of them are 8 or 10mm.
The whole pipe will drop down so watch out for coolant splashin in your eyes :eek7:
hope that helps.
