slow 3.8 V6
choochootrain
11-05-2002, 08:49 AM
I have an 89 Cougar LS. I bought the car like a year and a half ago. When I got the car it was slow off the line and still is. You step on the gas and it takes like 30 seconds for the motor to get up to speed. Would it be dirty injectors? Can I adjust the throttle cable at all? It has new plugs, wires, rotor and cap. It also has a newer but not brand new Tras in it. If anyone has any thing I can try let me know. Thanks:bloated:
jimjam187
11-05-2002, 10:44 AM
it could be on of 1000 things timing, cataiytic converter, fuel press. let me me know what kind of work u have done to it. its not the plugs.:sun:
choochootrain
11-06-2002, 11:35 AM
I haven't done any work on the motor or anything except for putting in a new trans. I plan to put duel exhaust on it some day soon. first i have to fix it though, because someone hit me and took off my whole front end. It's almost all toghther again, i have to get just a couple of more little things for it, then get it painted.:bloated:
jimjam187
11-06-2002, 12:21 PM
check the fuel pressure, timing, and buy some bg44 for it i can send you some if u pay for it. not saying the bg will fix all of the problems but you will be able to tell a remarcable diff. bg is a fuel induction system cleaner, and it has a fuel additive you put in your gas tank. you would need to find someone to put it in for you. it takes a special tool. good luck keep me posted.:smoker2:
choochootrain
11-08-2002, 11:22 AM
I checked fuel pressure and it is good. I've tried some different fuel system cleaners and they really don't seem to make a difference at all. Could it be the motor is not getting enough air?:bloated:
jimjam187
11-08-2002, 05:11 PM
not really. check the timing.
choochootrain
11-08-2002, 10:57 PM
I was gonna check timing this weekend when I finish putting the front end back on it. What if the timing is good then what could i check?:bloated:
choochootrain
11-09-2002, 05:09 PM
timing is good:bloated:
jimjam187
11-11-2002, 10:27 AM
sounds like exahaust is backing up somewhere. check it. let me know. if not that and check your compression ratio.:flash:
choochootrain
05-01-2003, 12:39 PM
I redid the exhasut system on my car and it seems to have more power now. I took out all the mufflers but left the cats in and put in a glasspack. Works good now. thanx for all the help.:bloated:
cougar4life
05-01-2003, 02:19 PM
hey check out cougarnuts.com
