If you guys can help me out on where to look but my power door locks does not work. Non of them, only way to lock them is manually on both sides. Ive check all the fuses which are good, where else should i look at? thanks!
Yeah i checked the fuses under the hood and there fine, but NONE of the power door locks work, so im trying to find out the source. I would click the switch but i hear nothing at all, not even the actuator moving.
I once had a broken wire in my old Chevy. Check out that wire harness that goes to the door.
Sometimes fuse looks good bad it is actualy bad. Pull them out and examine closely.
Remove the decorative panel and make sure you get power to the switches. That is probably the only choise you have if all your fuses are checking all right.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
I took out the decorative door panel everything is fine, but i took out the door lock control box that was in the door panel, Now how do I test the module to see if its working or not?
Make sure you get power to the control box. You need to download service manual from the links at the top of the forum stickies and find electirical diagram there. I have a feeling that this is a problem with the box itself.
Good luck,
Sam
