AC drain linedafeeder 07-07-2007, 07:20 PM Can anybody tell me where the AC drain line is located at on a 96 Windstar? My passenger side carpet is wet and I cannot find the drain line under the car. wiswind 07-08-2007, 11:19 PM I could be wrong.....but I think that it is on the firewall? Would be under where the A/C lines go in through the firewall. dafeeder 06-24-2009, 02:29 PM I found what appears to be some type of drain line boot coming out of the firewall and put a vacum hose in it and cleaned it out but the carpet is still getting wet. Any suggestions? 12Ounce 06-24-2009, 03:32 PM On some models the ac drain is covered by a foil heat shield ... making it difficult to find/see. There is also an exposed firewall drain from the heater coil box ... don't let this confuse you. dafeeder 07-01-2009, 03:44 PM On some models the ac drain is covered by a foil heat shield ... making it difficult to find/see. There is also an exposed firewall drain from the heater coil box ... don't let this confuse you. Thanks for the help and I will check into that. Since I can't find it I bet it's covered up. Automotive Network, Inc., Copyright ©2012
