Re: PGM-FI/ecu question on D15a3...
Keep the stock ECU.
With no supporting mods the Teg ECU is worthless and will actually hurt your motor's performance. Even people with a D15A3 producing 150HP prefer the stock SI ECU.
The problem is that the Teg ECU makes the D15A3 run rich, this means it is only good for wide open throttle (WOT) since it adds more fuel when the motor would normally start to run lean. This also means that the rest of the time the ECU is flooding the cylinders with gas and hurting the motors performance. Since most daily driven cars rarely see WOT, this swap has no benefit.
The only benefit of the Teg ECU is the higher rev limit, but are you willing to put up with a poor running motor just for a few extra hundred RPMs? Honda set the rev limit on a D15A3 for a reason and over revving an already tired 20 year old motor is a sure way to blow it up.
BTW, I tried the Integra ECU and it made my car run so rich that it failed a WA state emissions test twice. Once I put the stock ECU back in it passed fine. WA state has a pretty relaxed emissions standard, so if it didn't pass emissions here, it would definitely fail in any other state.
