Re: '90 Accord headlight problem
If you are going to splice in a new connector, make sure you solder the wires or use crimp connectors. The bulbs use considerable current and anything other then a very good connecton will cause the connection to generate enough heat to destroy your new harness. When using aftermarket bulbs make sure the wattage is no higher then the stock bulbs or you will melt the connector/wires.
