How do you remove crankshaft pulley for h22??
XMASTERX87
07-06-2007, 02:46 AM
I recently bought a H22 and im trying to take off the crankshaft pulley so that i can change the timing belt... now the problem is... its not comeing off... the valve cover is off and the timing belt came off of the cam gears as well...and right now i have no idea what to do since i cant put the belt back on due to the autotensioner... anyone got any ideas or solutions??
The engine is not on the car yet, its still on the wooden crate...
PLZ i need all the help i can get... asap...
AudioGuy93DelSol
07-06-2007, 05:36 AM
Impact. Call your friends and find the most powerful impact driver you can. Friend of mine has a ~700 lb/ft Snap-on that holds a record of 1,037,892 and 0.
Greenblurr93
07-06-2007, 08:14 AM
yep powerful ass impact, and dont use it to put it back on, use a less powerful one.
XMASTERX87
07-06-2007, 06:06 PM
Well... i have a shitty impact... its connected to the wall... yea.. i need to get a compressor... ive been reading that i can also jam the flywheel... can i do that?? or should i just go with the impact idea??
Greenblurr93
07-06-2007, 09:20 PM
umm impact.... unless you buy the special tool to lock the fly wheel.
XMASTERX87
07-07-2007, 02:04 AM
where can i buy the tool??
Greenblurr93
07-07-2007, 11:25 AM
a honda dealership. but think of it this way, buy the tool and use a couple times, or buy a nice impact and use it a lot
XMASTERX87
07-07-2007, 11:27 AM
But then again the timing belt isnt on it anymore so im afraid that if i turn my piston fast enough, i might damage my valves if it slips or something... thats y i want to use the tool... or something similar to that.
Greenblurr93
07-07-2007, 01:32 PM
an impact wont turn over the motor if it has enough torque. the first impact will break the bolt loose and then itll jus come off.... it may turn like 1/100 of a full turn... youll be fine, plus i believe that motor is a non-interference motor, so even at TDC with the valves all the way down, it wont hit
AudioGuy93DelSol
07-07-2007, 06:06 PM
H22's are iterferene. But like you said, the impact will turn the motor so little that you could have a friend hold the flywheel in place.
Greenblurr93
07-08-2007, 12:09 AM
ahh good to know.
XMASTERX87
07-08-2007, 03:07 PM
ahh good to know.
Something to keep in mind... the valve cover isnt on and the engine is on a crate... its not on the car... i can turn it over with my hand...
Greenblurr93
07-08-2007, 05:54 PM
right, it will only take a micro second for an impact gun to break the bolt loose, if youre that worried, have a friend hold the flywheel like Audio said.
