2000 Caravan overheating problems.d4v3 07-04-2007, 09:17 AM I have a 2000 caravan w/ 3.3 V6. My engine has started to overheat when the a/c is on in top/go traffic. As soon as you shut the a/c off the temperature goes right back down. I have checked the fan(s) and they seem to be working properly. Could this be a thermostat issue?? Thanks for the help !!! RickMN 07-04-2007, 02:46 PM Could be several issues. Start by checking the operation of the cooling fans. Start the car with a cold engine and turn on the A/C. The fans should come on right away. If they don't, you've got a problem. If they do go on, you could still have a problem with a coolant temp sensor, or a fan relay. The fans are two speed and perhaps they're not kicking into high speed when A/C is on. A bum T-stat would probably give you problems even when the A/C is off. d4v3 07-05-2007, 07:12 AM The fans are definetely working i checked them under hot and cold conditions. They seem to be operating correctly. I neglected to mention in my earlier post i was a little low on coolant (no leaks) but i don't think that is the issue. I will try the temp sensor. I may try the thermostat its cheap/easy enough to do and it will at least eliminate that possibility. -thanks Automotive Network, Inc., Copyright ©2012
