1994 4 runner water pump replacementrustyrun 06-28-2007, 08:08 PM Is this a big job? I am mechanically inclined but do not want to take all day doing this. I replaced the radiator as it was leaking and replaced the thermostat. Now I see a slow stream of water coming from the pump. I have read that you have to remove the timing belt as well. Any tips would greatly be appreciated. 3.0 v6 engine. Thanks VVTi 06-28-2007, 08:17 PM yeah that's a lot of work. let an expert do it for you. Brian R. 06-29-2007, 01:33 AM Here's a link from the FSM in the sticky post - top of this forum: http://personal.utulsa.edu/~nathan-buchanan/93fsm/engine/67timingbe.pdf http://personal.utulsa.edu/~nathan-buchanan/93fsm/engine/109waterpum.pdf rustyrun 06-29-2007, 11:12 AM do you have to remove the timing belt assembly or can you just remove and replace the water pump? Thanks for the sticky as this really helps. Brian R. 06-29-2007, 12:56 PM Yes, you have to remove the timing belt. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
