infiniti i30 keyless entry programming
candita
06-28-2007, 02:09 PM
can somebody give me the keyless entry programming procedure for a 2001 infinity i 30. Dealer wants 70 bucks for that.
Infiniti-Sales-CA
08-31-2007, 01:52 PM
Ok lets see if I can remember this.......
Get in the car and close doors.
Hit unlock, then lock again on the door. (not keyless entry)
insert key into ignition and turn to on position, then off position, then on position, then take key out.
now you have to insert key into ignition and remove about 7 times. When you do this the right way the lights will flash. (dont turn the key at all, just insert and remove)
Once you get the lights to flash then you have to hit the lock button, then unlock button on your keyless entry!
Open the doors and try the keyless entry.
If it doesnt work the first time try it a couple more times. If you have no luck after that than I'm sorry. That is the only way I know how to do it.
Good luck!
