hi,
i have a renault clio11 1.2 1999(v), the car has started to overheat, i think it is because the radiator fan does not spin to cool it down.
i took the switch off connecting to the coolant temperature sensor(CTS) and the fan starts spinning when the car is started, so i thought it would be the CTS, i have replaced this but the fan still does not spin, what could be the problem, do you think the thermostat could be causing the problem? the only thing about that is that when the fan spins(remember when i disconnect the switch from the CTS) the engine runs fine at half way temperature, so if the thermostat was not opening to let the coolant throught, wouldn't the car still overheat??
please can anyone help, i have already payed about £22 for a sensor i did not need
