Durango A/C problem!!!!???
Google
Web AF
TCHRISD
06-28-2007, 11:06 AM
I just bought a 2000 Durango V8. Well the A/C is not working properly. It seems cold air won't blow in the front but will in the back. Does anybody know what this might be?????
raamedicva
06-29-2007, 10:46 AM
I am looking for the answer to the same question. My mechanic is in the process of replacing the evaporator at the tune of $300.00. I will let you know if this fixes the issue.
nuhshar
07-08-2007, 11:43 AM
Im looking for the same answer on an 02 please let us know what you find
xj31
07-08-2007, 05:28 PM
The expansion valve might be stuck.
jennenga
07-08-2007, 05:58 PM
If your air is working in the rear but not the front,it sounds to me like you have a blend door that is obstructed and not operating properly. Or you may have a bad vacuum motor that controls the door. However, it also may be a vacuum leak in the line that supplies the vacuum motor.
TCHRISD
07-09-2007, 04:21 PM
I took mine to a mechanic and he changed out the expansion valve and the dryer and it made is somewhat better but it is still not cold enough. I am bringing it back in. I live in houston and it is hot.
inafogg
07-26-2007, 11:09 AM
are you getting air coming out of the front and its not cold or no air at all
TCHRISD
08-15-2007, 02:46 PM
the air blows and is somewhat cold only when the RPM's are up.
inafogg
08-15-2007, 03:13 PM
resistor problem if fan/air not blowing in front very common
jeep lover
09-16-2007, 09:49 PM
This A/C subject has been at the forefront ever since Durangos were born. I have a '98, and posted a thread back in 2005 or 2006 regarding the same issue. At someones suggestion, every spring after cold weather, I disconnect the heater hoses at the firewall, and splice them together. Then about the time cold weather starts up, I reverse them back to normal so we have heat in the winter. This does help, but frankly, Durango A/C sucks.. Most repair folks will tell you about $2500 to fix it, because they don't know where to start and don't know where they will wind up.
TCHRISD
09-17-2007, 02:37 PM
What exactly does this do?
jeep lover
09-18-2007, 07:46 PM
Well, if the blend door is stuck partially open, heat from the heater core is permeating the A/C system during the summer, keeping the A/C from cooling properly. Actually, a repair technician suggested that, because he could not tell me exactly what all the issues were with the A/C unless he spent 8 hours taking it apart. So I tried it and it has worked for the past three years.
Google
Web AF
