Re: abs not working
Originally Posted by youkoi
i am looking for somone who can tell me how to turn off the abs on my 92' corsica. the reason i want to turn it off is because my right brakes are grabbing but my left the abs is working fine. this isnt a good combo and i dont have money at the time to fix it. so please help me as soon as possible.
thanks
You can pull the fuse, or unplug a wheel speed sensor. On my '96 any time the ABS light is on, the ABS doesn't work. Caused me to go into a ditch shortly after "drifting" around a corner with the hand brake
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
'86 3/4 ton Silverado
350 V8, 4x4, 4" lift, 1 ton axles swapped, converted to 4 wheel disc
35" BFG Mud Terrain T/As
Shortened to 109.5" wheelbase for those tight trails
http://www.boycottpepsico.com/default.aspx
You see "Fresh oil, loose gravel"; I see "Free undercoating"
