dashpotrking828 06-27-2007, 11:33 AM can the dashpot system be removed with out harming systems i think its causing wierd idle problems TcmaBoy 06-27-2007, 01:10 PM What led you to believe that it is the source of the problem? rking828 06-27-2007, 03:30 PM checked tps and it is good trying to figure out the problem rking828 06-27-2007, 03:31 PM at idle the car will rev up to about 1500 if you tap the gas it will drop back down any suggestions would be appreciated TcmaBoy 06-28-2007, 01:05 PM Have you checked for vac leaks? Have you made any adjustments to the idle screw? rking828 06-28-2007, 03:38 PM have not checked for vac leaks yet but will do that thanks one of the other things i noticed is it only does it after it gets to operating temp vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
