Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 06-22-2007, 12:22 PM   #1
Ratazc
Ratazc Normal reputation
'96 Jimmy SLT Starting problem
This starting problem is a little strange for me. It only happens in the morning
perhaps when its been sitting for over 8 hours...anyway....
It cranks over and over .... pause, try again ....almost starts .... pause
... I repeat this for some 10 to 15 mins ... then it starts ....
I thought it was the fuel pump at first, but if it was that ...why does it
start up...then go all day. Then happens again the next day.
I did notice that each day its taking longer for it to start....any suggestions
as to what to look for?
Thx.
Ratazc is offline   Reply With Quote
Old 06-22-2007, 01:05 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: '96 Jimmy SLT Starting problem
Welcome to AF.
When engine is cold it needs full fuel pressure to squirt the injectors cold.
Even a couple of lbs. low can cause a no start cold.
Hard to start cold.
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
Later V6 and V8 gm engines should have 60-66 fuel pressure.
Cold start should be 64-65 lbs of pressure.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Do not leave home without it.
Engine running should be 60-66 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak.
Post back fuel pressure readings.
MT
MT-2500 is offline   Reply With Quote
Old 06-22-2007, 01:05 PM   #3
blazes9395
Newbie mod
blazes9395's Avatar
blazes9395 Normal reputation
Get a fuel pressure guage on there and see what your getting when this is happening.
blazes9395 is offline   Reply With Quote
Old 06-22-2007, 01:07 PM   #4
blazes9395
Newbie mod
blazes9395's Avatar
I was going to go into more details, but I thought i'd check to see if MT posted and yes he beat me to it, follow his advice....
Old 06-22-2007, 01:23 PM   #5
MT-2500
AF - Advisor
MT-2500's Avatar
blazes9395
If I had know you were answering it I would have let you have it.
But it is hard to resist a hard start cold problem.
Go ahead if you want to help him.
MT
MT
Old 06-22-2007, 05:12 PM   #6
Ratazc
Thanks for your reply.......
(w/ engine warm/hot)
With just ignition on I get 54lbs.
Kind of stays around there with engine on.
I shut off engine....pressure doesn't really fall.
I didn't understand that "pinch off at rubber part"....
I guess yo mean the bleed off tube?
So I need to check after it cools off...I guess tomorrow morning.
Do you think it may still be the fuel pump? I changed it last year...around
this same time. Then I couldn't even hear the pump running.
Again Thanks.
Originally Posted by MT-2500
Welcome to AF.
Hard to start cold.
Old 06-23-2007, 07:16 PM   #7
Ratazc
So with it cold ....reading on guage is the same. actually it has lowered to
50 lbs. After a long time I got it started again...while in idle needle jumps
from 50 -54. While accelerating it (in park)...it stays a constant 50.
I replaced the gas filter...same. Do those extra 6-12 lbs of pressure make
that much of a difference?
Old 06-23-2007, 10:27 PM   #8
MT-2500
AF - Advisor
MT-2500's Avatar
Sure do.
Why do you think you are having cold start problems.
Even a couple of lbs low can give you a no start cold.
If you do not have full fuel pressure do not leave home without it.
MT
MT
Old 06-25-2007, 01:30 PM   #9
Paul Hayes
Paul Hayes Normal reputation
Sure do.
MT
Hello, I have a 1996 Jimmy SLT and it is doing the exact same thing. Are You saying it is the fuel pump that needs to be replaced? Thanks for any response. Paul
Paul Hayes is offline   Reply With Quote
Old 06-25-2007, 05:51 PM   #10
blazee
I'm gonna punch yo momma.
blazee's Avatar
blazee +50blazee +50
Click here to start your own thread and someone will help you diagnose your problem properly.
http://www.automotiveforums.com/vbul...wthread&f=2072
blazee is offline   Reply With Quote
Old 06-25-2007, 05:55 PM   #11
MT-2500
AF - Advisor
MT-2500's Avatar
Welcome to AF On your first post.
No I am not saying the fuel pump needs replaced.
I am saying check fuel pressure and if you do not have full fuel pressure do not leave home without it.
Please start a new thread on your jimmy and some one will help you.
Two different problems on one post will get you two different answers.
Just go to new thread and give us all of you info.
What it is doing or not doing and mileage and engine info.
Repair and tune up history helps to.
MT
MT
Old 07-07-2007, 07:59 PM   #12
Ratazc
OK so I finally replaced the fuel pump.....it starts now BUT the pressure is the same...54lbs...never gets up to the 60-66 lbs range.
Bookmarks
Google
Web AF
