Re: problems with T& C 2003 dying
Many possibilities. Especially tough to say without a code. Here's a few ideas in no particular order:
> Take a look at the Idle Air Control valve/motor in the throttle body. This valve controls idle speed in multiple modes. Make sure the connection is tight and the contacts are clean. Consider cleaning it and testing it. While there clean the throttle body.
> The EGR system is infamous for causing idle/stall issues. Check it's operation and clean/lube the valve stem and inspect for loose connections, clogged vacuum lines, etc.
> Inspect the crank and camshaft position sensors and connections. These sensors help determine engine timing and are known to cause stalling issues. They are easy to change and cost $20-$30 each.
> Inspect the coil and spark plug connections. Make sure they are tight. Seal them with dielectric grease especially if you frequently drive in wet conditions.
All of these components are supposed to generate an error code when they fail. Many times they don't. Does it start up again right away? If not check to make sure the engine is getting spark and fuel.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
