06-19-2007, 10:40 PM
Alternator Voltage Output: 2001 5.3
I was wondering what you all see for your alternator's output. I had a 105amp alternator and it usually stayed at or just above 14 volts.
I installed a new 145 amp alternator and it is at 14 volts just after startup then it goes under 14 (like 13.5 volts).
Is that normal range? These are internally regulated right?
2001 5.3 LS Stock
6 channel Alpine 3566 Amp
Jason Extreme Slam Camper Shell
Michellin X-Radials
79K Miles
06-20-2007, 10:27 AM
Re: Alternator Voltage Output: 2001 5.3
Mine typically stays right at 14 too, and it's stock. I think I remember it going higher when I was jumping somebody, but that's the only time it's ever changed.
06-20-2007, 10:36 AM
AF - Advisor
No problem as long as it keeps the battery charged and carries the load at 1K rpm with everything turned on.
Also a dash gauge may be off a little bit.
Put a volt/ohm meter on battery for a true test.
MT
06-21-2007, 10:13 AM
Typical alt output as measured at the batt terminals should be 14.2 to 14.7 volts. Use a digital VOM to check it.
"R57 3CAR" 210 2dr post. 420HP 355 F/I 4sp 3:42 posi. (Dale Earnhardt tribute done by me.)
75 GMC Vandura 3/4 Ton
78 Chevy K5 Blazer
98 Chevy K2500 Suburban LT/7.4
05 Dodge Ram 3500/Cummins (Wifes horse hauler)
06-21-2007, 11:00 AM
Ok, I will put my Fluke on it and see this evening. I notice at startup it is usually just over 14 but once the truck warms up it is below 14 (by the dash gauge anyway).
2001 5.3 LS Stock
Michellin X-Radials
79K Miles
06-22-2007, 08:37 PM
your output should stay about the same, but it can handle much more load.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
06-23-2007, 12:11 AM
Thats what I thought: maybe when i load it up it would climb, but it doesnt.
I have a 6 headlight setup (hi/lo/fog), 6channel amp, AC on, interior lights on and the volts kind of get lower as everything gets turned on.
I thiink this one was wound kind of weak. It was listed as "NEW" Factory take-off, now I know why they took it off
Kind of like snakeoil  opcorn:
Well I have another one coming so I will know for sure.
2001 5.3 LS Stock
Michellin X-Radials
79K Miles
06-23-2007, 10:43 AM
AF - Advisor
You might as want to check check the base battery voltage.
As long as charging voltage is over battery base voltage and battery stays up good and it carries all of the load when running it should be good.
With a good battery alt tester.
Run a pile load test on it and see if it is putting out full amp at 2500 rpm.
Older ones the charging voltage was in the 14.5-14.7 volt range.
Newer ones you are doing good to get 14 volts.
If I see 1/2 to 1 volt over battery voltage I call them good.
MT
MT
06-24-2007, 02:30 AM
MT
So the newer alternators are regulated lower, is that what your saying? Why would they do that? Is there a way to adjust the voltage?
2001 5.3 LS Stock
Michellin X-Radials
79K Miles
06-24-2007, 03:21 AM
AF -Advisor
No, you cannot adjust voltage. Remember, 12.6 volts is standing voltage on a fully charged battery (2.1v/cell, 6 cells). The specified alternator output design is 13.8 volts - this is what your vehicle electrical system tries to maintain. There are a lot of computerized systems on these vehicles, from the airbag system to the radio and including the PCM. These aren't very tolerant of overvoltage, so the regulators are tighter now than in the past.
14 volts in my opinion is still a little high for alternator output on a system with a fully charged battery, 13.5-13.8 is nominal operating voltage. MT nailed it when he said charging output .5 volts higher than nominal battery voltage is good - it means the system is operating as designed.
To sum it up in 5 words -
There's nothing to worry about.
A higher voltage might make your lights brighter and your amp a little louder, but it will also shorten their life. It will also shorten battery life, especially if you have an Optima battery.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
PC Club is dead. Long live PC Club!
06-24-2007, 10:20 PM
Did you find a kit for the 6 light or how did you do it?
06-24-2007, 10:46 PM
I added a set of Bosch Relays. It was a kit from Mrtaillight on ebay I think. Let me see if I can pull up the item #.
2001 5.3 LS Stock
Michellin X-Radials
79K Miles
06-24-2007, 10:50 PM
Here it is:
ebay Item number: 200086509713
**HINT** He will take $16 + Shipping when you submit best offer. If you look at his auctions for these, some of them are priced much higher for same item, if you search through you will find them much cheaper, then submit best offer.
2001 5.3 LS Stock
Michellin X-Radials
79K Miles
