Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 06-19-2007, 07:45 PM   #1
96wWindstar180K
96wWindstar180K Normal reputation
Ac compressor leaking
I have a 96 S10 Blazer with 4 wheel drive 4.3 litre engine. The compressor has a leak between the back plate and the compressor itself. Is there a seel around there. I dont see one on the exploded view in Alldata. The only seal I see is the front seel behind the clutch the o rings where the hoses connect and an o ring for the high pressure cut off mounted in the back plate. I replace the o ring and the switch because I thought it was leaking by that o ring but the dye shows up all the way around the connection between the back plate and compresor. Any ideas?
96wWindstar180K is offline   Reply With Quote
Old 06-20-2007, 09:41 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: Ac compressor leaking
If the compressor itself is leaking it may be time for a new compressor.
There is a seal on the case half but sometimes you can never get them to seal up.
Most parts places have a line of New or rebuilt compressor at a good price.
Google AC-Kits.com
For some good info on them.
MT
MT
MT-2500 is offline   Reply With Quote
Old 06-20-2007, 07:43 PM   #3
96wWindstar180K
MT-2500
Thanks for the information. I ordered the seal and other O rings as well a the dryer. Ill give it a shot and see what happens. By the way the Web address is www.ackits.com for anyone else looking for parts. Thanks
Old 06-21-2007, 08:47 AM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
Originally Posted by 96wWindstar180K
MT-2500
You are welcome and good luck on it.
MT
MT
Bookmarks
Google
Web AF
