I have 93' 4.3, CPI, s-10 Blazer Vortec. My prop is this for awhile there i kept gettin code 22 which is Throtle Position Sens (signal voltage Low) and code 43, Electronic Spark Control= which deals with knock sensor well, up intill today ive checked TPS and the readings check out with a Digital Voltmeter, but code is still on?? any ideas on that?? The knock sensor i cant get a reading out of it, or im just doing it wrong,but it seems i cant get a reading out of the connector either. Any ideas on that?
Ive fixed several things fuel pressure regulator,Nut Kit,plugs,wires,PCV,oil, Seafoamed through Brake Booster, and soon to be fuel filter. All while have somewhat eradict idle and low power, sometimes heasitation during low RPMS takeing off stumbleing crap. Now i get a IAC, Idle Air control Valve code 35 but TPS code 22 is gone. Checked readings on IAC and they where between 40 and 80ohms like its supposed to be. Any ideas out there guys? Ill try almost anything you guys recomend. O and also about that 43 code i cant get the Knock sensor out of block.
Ive tried warming engine up,PB blaster all day long and still nothin, any help with that? Thanks again sorry for winded post,tryin to include everything Thanks again Chevy guys
