Please Help/Headlight,Horn, etc. problemsMrs.Debbie 06-18-2007, 04:52 PM I have a 1994 Ciera. My horn doesn't work, my dome light doesn't work, and my headlights won't come on. I checked fuses and changed headlights. Nothing is working. Car runs really well, but now can't drive it at night. Please help. thanks Mrbizness1 06-18-2007, 10:34 PM I have a 1994 Ciera. My horn doesn't work, my dome light doesn't work, and my headlights won't come on. I checked fuses and changed headlights. Nothing is working. Car runs really well, but now can't drive it at night. Please help. thanks Did you look at the Ctsy fuse? On most Ciera's it controls the lighter, dome and interior lights. When you push the light switch do your tail lights work? Mrs.Debbie 06-18-2007, 10:37 PM My tail lights work.........my turn signals work. Interior light, headlights, and horn don't work. Where would this fuse be? I'm sorry, but I don't know anything about cars. If you can explain where this fuse is, I can check it. Thanks Mrbizness1 06-18-2007, 10:50 PM My tail lights work.........my turn signals work. Interior light, headlights, and horn don't work. Where would this fuse be? I'm sorry, but I don't know anything about cars. If you can explain where this fuse is, I can check it. Thanks On my Olds it was in or near the glove box area. It has a small plastic door you must pull to open. On some year models its under the dash. There might also be a relay box under the hood. You should also have front clearance lights that go on with the headlights, if they are not working than you probably have a wiring problem. With the switch on try moving some wires around near the headlights. How long have you had this problem? Automotive Network, Inc., Copyright ©2012
