Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
Become a subscriber. Browse a faster, ad-free AF. Instantly.
Automotive Forums > Chevrolet > Blazer > Performance - 92 2.5 to 2.8 swap
User Name
Password
Register FAQ Member Map Calendar Surveys/Quiz Arcade Mark Forums Read
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 06-17-2007, 11:43 PM   #1
speedindevil
speedindevil's Avatar
Send a message via AIM to speedindevil Send a message via Yahoo to speedindevil
Question 92 2.5 to 2.8 swap
Anyone know how much stuff I would have to change on my truck to go from a 2.5 4 cyl to the 2.8 v6? I was trying to do some crossreferencing on parts to see which ones interchange, and I got as far as the clutch, and fuel pump, supposedly the clutch kit @ advance auto parts is the same for both trucks, flywheel is different, but I'm thinkin that's just for balance reasons and crank bolts, but I'm wondering if anyone knows if the alt is the same, if I can use the same radiator, and how much of the wiring harness I'm gonna have to splice, also will the rear of the motor be in the same location, or do I have to fab a tranny crossmember and change my driveshaft length. ?? Only reason I'm asking is cause I have a 2.8 that I can put in for free, and my 2.5 is getting kinda whooped (192,000) Any and all help is as usual greatly appreciated.
Josh
"If you have tried to do something and failed, you are vastly better off than if you had tried to do nothing and succeded"-----(someone famous)-----
speedindevil is offline   Reply With Quote
Old 06-18-2007, 08:36 PM   #2
bigd7315
Send a message via Yahoo to bigd7315
Re: 92 2.5 to 2.8 swap
why would u go through the trouble the 2.8 has like 140hp and the 2.5 has like 125 and gas milage is the same and the 2.5 is a more reliable motor if you are going through that much trouble small block it
bigd7315 is offline   Reply With Quote
Old 07-07-2007, 02:58 AM   #3
speedindevil
As I said I can get the 2.8 for free, also I can get a 4.3 for free, but I'm worried about the gas milage on the 4.3 tranny, etc. and my 2.5 has a worsening lifter knock
Old 09-04-2007, 05:02 PM   #4
jackpot5283
once again dont put a 2.8 in anything every single one ive had has spun a bearing first time i revved it up would reccomend either the 350 or find a used head even if 2.8 is direct bolt in its a (s)crap motor and the best thing gm ever did to it was discontinue it. the 3100 3300 variants are good motors but still underpowered for a toy imho
jackpot5283 is offline   Reply With Quote
AF Assistant
These Ads Open in New Window
User Name
Password
vB code is On
Google
Web AF
© 2000-2008 AutomotiveForums.com | Privacy Statement
