Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 06-17-2007, 01:17 PM   #1
mykeymykenc
mykeymykenc Normal reputation
need help cause i'm stumped
i have a 1995 Gmc 2.2L 2WD Ext. cab pickup. it would not accelerate, backfire then stall while driving. i changed to fuel filter made sure there was no leaks and made sure it was installed correctly. now i cant get it to start back up. did i need to prime the lines or something??? any advice would be helpful
mykeymykenc is offline   Reply With Quote
Old 06-18-2007, 08:34 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: need help cause i'm stumped
Has it got plenty of fuel i n the tank?
Can you hear fuel pump run?
If so check fuel pressure.
MT
MT
MT-2500 is offline   Reply With Quote
Old 06-18-2007, 08:56 PM   #3
jackass#1
jackass#1's Avatar
jackass#1 Normal reputation
Send a message via Yahoo to jackass#1
check fuel pressure, sounds like the pump.
jackass#1 is offline   Reply With Quote
Old 06-19-2007, 04:37 PM   #4
BlazerBoyLT98
BlazerBoyLT98's Avatar
BlazerBoyLT98 Normal reputation
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Does sound like the fuel pump, same thing happened to me. I had it towed and the bumps cause it to work again for about an hour but stalled on me again and needed to be replaced. Mine actually still doesn't read right after replacing the pump and the sending unit. Good luck
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
BlazerBoyLT98 is offline   Reply With Quote
Bookmarks
Google
Web AF
