Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 06-16-2007, 07:56 PM   #1
gfrancis
gfrancis Normal reputation
Cool electical problem???
Hi, my van wont start, while driving the other day the air bag light came on,(and was on for a sec, and went back off) and the interior lights started to flash on and off and the power locks started clicking...now there is a clicking noise not coming from the engine its under the dash, by the fuse box....Now it want start, wont even crank over and the electic locks wont work........email me @...glefromks2002@yahoo....
gfrancis is offline   Reply With Quote
Old 06-16-2007, 07:57 PM   #2
meddleswithmetal
meddleswithmetal Normal reputation
Re: electical problem???
sounds like the body control module to me....
meddleswithmetal is offline   Reply With Quote
Old 06-16-2007, 08:08 PM   #3
gfrancis
Okay, Is this hard to fix? where is is located at? How much they cost? Or should i take it to be fixed?
Old 06-16-2007, 09:05 PM   #4
Stretch58
Stretch58 Normal reputation
Sounds electrical alright. Start with the battery, make sure you have a good one.
Retired USAF/ Nuclear Plant Controls Dude
Had Recently
1996 Caravan 3.0 Great Car
2005 Impala 3.8
Now
2000 GC 125K 3.3
2006 T&C 3.8
Stretch58 is offline   Reply With Quote
Old 06-17-2007, 02:48 AM   #5
RIP
AF -Advisor
RIP's Avatar
RIP Normal reputation
Model Year?
The BCM should be on the back side of the junction block under the left side of the dash. It's in the mix but, as stated, look at the battery first. Make sure it is fully charged and the posts are shinny clean and tight. Car computers are sensitive to weak batteries. Make sure the battery ground connection to the frame is clean and tight.
EDIT - should be left side of the dash.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
RIP is offline   Reply With Quote
Old 06-17-2007, 11:43 PM   #6
gfrancis
Originally Posted by RIP
Model Year?
The BCM should be on the back side of the junction block under the right side of the dash. It's in the mix but, as stated, look at the battery first. Make sure it is fully charged and the posts are shinny clean and tight. Car computers are sensitive to weak batteries. Make sure the battery ground connection to the frame is clean and tight.
2000 Dodge Caravan 3.0 liters.....
Old 06-24-2007, 11:37 AM   #7
gfrancis
Thanks, it was a dead battery, but now after getting a new battery, my cruise control will not work or the horn, is it possible that i may need to get it re programed after i had that dead battery????
Old 06-24-2007, 11:44 AM   #8
Stretch58
Glad you got the first problem fixed. A new clockspring wiring cable in the steering column/steering wheel should take care of the the other 2 problems. It allows circuits inside the steering wheel, which of course turns. I would have the dealer do it. They may do it for free, there is a recall on it.
Had Recently
2005 Impala 3.8
Now
2000 GC 125K 3.3
2006 T&C 3.8
Old 06-24-2007, 10:08 PM   #9
vipergg
vipergg Normal reputation
Might not fix anything but go under the hood in fuse center and find the IOD fuse and pull for a couple minutes and see if anything happens . If the horn and cruise worked before the battery change ok its probably not a clockspring .
vipergg is offline   Reply With Quote
Old 06-26-2007, 06:40 PM   #10
gfrancis
Ok, What is the IOD fuse???...which one is it?
Old 07-01-2007, 11:50 AM   #11
gfrancis
It was the clockspring had a recall on it,,Thanks for all your help....
Old 07-01-2007, 12:06 PM   #12
Glenn0921
Glenn0921 Normal reputation
I have a 98 dodge caravan with an electrical problem or something with the Instrument guages going dead then returning to normal, I know it's not a fuse. Can someone tell me could it be a ground wire or what? On very Hot days especially it seems to go out often......Please Help.
Glenn0921 is offline   Reply With Quote
Old 07-01-2007, 04:03 PM   #13
RIP
AF -Advisor
RIP's Avatar
gfrancis - thanks for posting the fixes
Glenn0921 - no need to post your problem twice
Bookmarks
Google
Web AF
