Towing with Taurus??97TaurusGuy 06-13-2007, 07:09 PM Anyone know the towing capacity of a 2001 Taurus w/ Vulcan?? e_powers 06-13-2007, 07:31 PM less then what the factory says. the engine can handle towing. but the transmissions are a weak point in Tauruses. if you plan on doing any towing add a top of the line tranny cooler and make sure the servicing on the tranny is up to date ie the all the fluid changed as well as the filter. 97TaurusGuy 06-14-2007, 07:31 AM less then what the factory says. the engine can handle towing. but the transmissions are a weak point in Tauruses. if you plan on doing any towing add a top of the line tranny cooler and make sure the servicing on the tranny is up to date ie the all the fluid changed as well as the filter. I know all that. I am wondering what the factory says what the towing capacity is. 65comet 06-14-2007, 08:51 AM If you go to the Ford website, search for parts, that screen has a link for owner's manuals that go back to 1996. It says in the 97 Taurus manual that a vulcan engine with the car having two passengers and no other gear/passengers can tow a max of 500 lbs. More passengers or weight in the car lowers the tow capacity. A duratec motor is listed with a max 795 lbs. Automotive Network, Inc., Copyright ©2012
