Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Xterra > How-to's & Installation
How-to's & Installation Share your techniques with other owners.
Old 06-12-2007, 01:12 PM   #1
Rotorman
Rotorman Normal reputation
Replacing fuel filter on a 2002 xterra
Hello there, just got finished replacing a fuel filter on a 2002 non supercharged 3.3 xterra. Took me 2 1/2 hrs learn form my mistakes.
Highly advised you jack up truck behind rear passenger door. Have less than 1/2 tank of fuel and leave gas tank cap off to reduce internal pressure.
tools on hand : 3/8 rachet with 10mm socket,medium size phillps screwdriver,
protective goggles for your eyes, spray lubricate to loosen
bolts, needle nose pliers, 1 3/16 vaccum cap to stop the
fuel near your head & put this cap on the old filter pinicle.
also have a oil pan to catch your gas! you'll lose about a quart.
after jacking truck up near max range. Take 15 amp fuse from top left hand corner out. start truck till it stops do this 2 more times.Take cap off
gas tank get under truck on the rear passenger side, and remove 3 bolts with
the rachet and 10 mm socket. Then loosen stainless steel clamps with the phlippshead screwdriver. Pull out one hose at a time and put the new filter.
This is where you need the vacuum cap to stop the flow. beware nissan does not give you extra fuel line going into the filter. This will be tough due to limited
access. the rest is obvious, and have extra dry rags and paper towels, you will need it. I hope this
gives you the inside track on getting this job done in 30 minutes or less. Good luck have a great hot shower to get the gas off your body.
Rotorman
Rotorman is offline   Reply With Quote
Old 06-12-2007, 10:00 PM   #2
OffroadX
OffroadX Normal reputation
Send a message via AIM to OffroadX
Re: Replacing fuel filter on a 2002 xterra
Thanks, but already covered...
http://www.automotiveforums.com/vbul...d.php?t=101513
When did you last check your spare tire's pressure?
OffroadX is offline   Reply With Quote
Bookmarks
Google
Web AF
