Re: Second time in 3 months batter has been dead
I would make sure the battery is good by having it charged then have it load tested. Take it back to where you bought it or I believe Autozone will do it free.
If the battery is OK you probably have a trickle drain, ie something is drawing current (power) when it shouldn't be. Glove box light and under hood lights are the at the top of the list. Then there's the malfunctioning components like window and door lock motors.
If the lights aren't on, there is still a way to find the culprit. Using the DC amp function of a multimeter, disconnect the negative battery cable and connect the meter leads to the disconnected cable and the negative battery post. This is called a series connection and must be used to detect current. If you're seeing much more than 100 milliamps you have a drain. To find it, remove fuses one at a time until the meter drops to 100 milliamps or less. The drain is somewhere in the circuit that fuse protects. Start disconnecting components in that system until the current drops to normal. It could just be corrosion on a connection.
Your alternator is probably good but, to verify use the DC volt function of a multimeter and measure voltage at the battery posts with the engine running. Should see at least 13.5 volts. This indicates the alternator is supplying enough voltage to charge the battery.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
