Re: 98 dodge grand caravan 3.3
Not sure what a DIYer is going to tell that you don't already know but, here's what I would do.
First, welcome to the forum. Second, I'll assume the dash lights are lighting when you turn the key. Third, your problem is the starter will not rotate the engine, correct? Power path for starting is the battery/ignition switch/neutral start switch/starter relay/starter solenoid/starter and indirectly from the PCM. You've eliminated the starter and solenoid. Check the circuit from the connections at the starter backwards to the battery. Your problem is upstream from the point you loose the voltage with the key turned. It appears the PCM supplies a ground to the starter relay coil. Will it crank if you supply that ground?
Why are you checking the fuel pump if the engine won't crank/rotate? Are you not telling us something? If the ASD system is tripped, you can crank the engine all day. Just won't start...or so I've read.
Does the starter relay click? It's quieter than the starter solenoid click. Have you tried wiggling the gear shift as you try to start? Neutral start switch may be out of adjustment or corroded.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
