Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Mazda > MX-5/ Miata
Old 06-09-2007, 05:06 PM   #1
Grenyaer
Grenyaer Normal reputation
Send a message via AIM to Grenyaer Send a message via MSN to Grenyaer
Installing a new soft-top
I'm in the market for a new top to replace my ripped up, gross and dirty one.
Has anyone here replaced one of these? Is it a DIY job? If so, do you remember what tools were needed? Nothing more annoying than getting half-way through a job and needed to go out and buy/borrow a tool to finish it.
Grenyaer is offline   Reply With Quote
Old 08-19-2007, 09:42 AM   #2
dtrivin
dtrivin Normal reputation
Re: Installing a new soft-top
I just replaced the top on my '99 Miata. After shopping and reading for a couple of months, I chose the Duetto Glasfold top. <http://www.duettomotors.com/miata/miata_tops/tops_glass_intro.htm>
One of the reasons I chose this top was because I liked the smooth design around the rear window. While installing, I was very impressed with the quality of design and construction.
The instructions they provide are very comprehensive and the special tools that I needed beyond the usual were:
1. A pair of long needle nose pliers
2. rivet gun
3. torque wrench that can at least register a range of 78-101 inch/pounds of force.
4. right angle ratcheted philips head screw driver.
5. double sided mounting tape.
6. patience :-) This was the first top I installed and over the course of a week, I probably spent about 12 hours to complete the install to my satisfaction.
Once the top was installed, it was very hard to close and I had to loosen the rain rail retainers to get it latched, even with the latches at full extension.
As you can see below, it was worth the effort.
After the top stretched out a little more, I took off the rain rail retainers, re-aligned the top and then tightened everything to spec. I am very satisfied with the top.
Daniel
dtrivin is offline   Reply With Quote
Old 08-20-2007, 11:51 AM   #3
abrittis
abrittis Normal reputation
Hello,
Go to http://www.miata.net/ and check out the garage section. There is a lot of information about replacing a soft top.
I replaced my '94 top with a Robbin's no-zip top. It took me about 10 hours. It's probably as complicated as changing out a clutch. It's a doable job if you are pretty handy. If not, it is best left to a professional.
Anthony
abrittis is offline   Reply With Quote
Old 02-08-2008, 11:56 PM   #4
FlyingHigh2
FlyingHigh2 Normal reputation
I am about to replace my top on my 94 with a Robbins No Zip w/glass window, myself. They even had a PDF to print of the instructions, for free!!!!! I'm gonna take my time also. Scott
Originally Posted by abrittis
Hello,
Anthony
FlyingHigh2 is offline   Reply With Quote
Bookmarks
Google
Web AF
