Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 06-07-2007, 03:02 PM   #1
buzz123
buzz123 Normal reputation
92 Lumina 3.1L starts and drives but sputters/dies intermittently
symptoms are: starts and drives every time hot or cold but
sputters/dies intermittently while driving. toward warmup sputter
seems to worsen as opererting temperature is reached.
Additionally, seems to sputter/die only in gear, not in park at
idle.
additional info: has 226k miles. have replaced (over the years of
ownership) ECM, CPS, computer module and most recently plugs.
any troublshooting ideas would be appreciated.
buzz123 is offline   Reply With Quote
Old 06-07-2007, 03:35 PM   #2
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
Re: 92 Lumina 3.1L starts and drives but sputters/dies intermittently
welcome to AF Buzz. There are quite a few things that can cause what you describe.
IF it stalls mostly as you come to a stop, it could be a stuck torque converter lock-up solenoid that's not unlocking the converter as you slow down. It would buck and studder just before stalling if this was the case (like coming to a stop in a stick shift car without taking it out of gear or pushing in the clutch pedal).
If it randomly dies while driving, you need to check to see if you have spark and/or proper fuel pressure when it dies.
Lack of proper fuel pressure (41-47 psi key on/engine off) could be a bad fuel pump, clogged filter, or a bad fuel pressure regulator.
Lack of spark could be a bad crank position sensor, ignition module or ECM, or the wiring to any of them.
Would you drive any better with that cell phone up your ...?!
richtazz is offline   Reply With Quote
Old 06-08-2007, 01:45 PM   #3
buzz123
Hello richtazz and thanks for reply,
Do u have know type of tools used to check spark and fuel pressure while driving ? Do u know any software and interface cable output to laptop computer to record engine performance ?
Old 06-15-2007, 01:13 PM   #4
buzz123
While awaiting fuel pressure gauge to arrive removed IAC and EGR valve, cleaned and installed. both looked in good condition. No change in symptoms. Will install fuel filter while waiting for fuel tool.
Old 06-16-2007, 02:47 PM   #5
buzz123
Installed fuel filter...symptoms changed a bit but still sputters/dies at operating temp. Now flashing code 22.
Old 06-20-2007, 04:55 PM   #6
buzz123
Checked fuel pressure at rail... steady 40psi. Can anyone tell me if this confirms fuel pump and FPRegulator are functional?
Bookmarks
Google
Web AF
