OBD Connectors70camaro 06-05-2007, 10:22 PM I have a 94 metro. It has a 12-pin Data Link Connector. Manual says I need a "Tech 1" scan tool. Is there an adapter or cable I can use to connect this to my OBD2 scanner? hot_sd 06-07-2007, 01:53 AM I believe OBD1 and OBD2 are not compatible - you will probably need an OBD1 scanner. 70camaro 06-15-2007, 11:52 AM OK, I got this info... You can get a cable from "akmcables.com" and then download "winaldl" to a laptop, and you should be able to get the the realtime sensor data.. just like the "tech1" would. If anyone has already done this, please post your success or failure... thanks! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
