Re: 95 geo metro Emissions
I wouldn't stick anything down the engine unless the engine was causing me a problem. If the engine has a lot of miles on it, engine cleaners will likely loosen up things that you don't want loosened. I would expect it to remove the carbon off the walls of the cylinders, causing the rings to not seat properly anymore.
Another option is to fuel your car with premium next time and let the additives in it do what they are supposed to.
And, if the catylitic converter has never been replaced, than it is likely not doing it's job anymore. Although I'm not a full supporter of this technology, (because if you don't replace them they make emissions worse) it is also a likely cause of the high emissions found in the test. Luckily, there is only one cat on the 95!
Jai
95' 3 cylinder manual 250 000km
96' 3 cylinder manual 250 000km
