Body almost done, short view with the wing... I like it, esp the sides of it.
As next IŽll start the stance, I need to get it about 3mm down.
Never did this on a Tamyia kit before, I think it will be fun 8)
Thanks guys, the wheel lips from the kit I didn´t use so far, I borrowed these from Aoshima Racinghart CR set.
The fender came with the kit, 2 parts to add to each side.
At first I cutted out the inner part and replaced it with the resign part.
As next I worked the arch to the old fender.
I finished the wheels, made the rear ones 0,75 mm wider with Plastruckt square styrene stripes. These on the second pic on the left.
I lowered the suspension as well, no pics of that so far... To explain how, I removed the holdings for the brake discs and glued them back 1mm higher.
Not realistic, but easy and still working
