88 Jeep Cherokee Pioneer won't start
emongear
06-04-2007, 09:18 AM
Hey my Jeep turns over but won't start. We changed spark plugs, wires, distributor cap, and rotor buttons, and still the same result (and we verified it was getting electricity and gas), So how do I check the compression (or repair it if that is the problem)? Also when you start the engine, you can hear some pressure release from the engine. Help please!!
AlohaBra
06-06-2007, 09:34 PM
Are you getting a spark from the spark plug wire.
Check compression with a compression gage.
Do one cylinder at a time.
citizen@large
06-07-2007, 03:35 PM
CPS (crankshaft position sensor)
wwwildman
06-09-2007, 08:08 PM
Check for spark at the coil first.
If you have no spark then look at the following:
1. Crankshaft position sensor
2. Ingition coil
3. Ignition module (test it at auto parts store)
4. Camshaft position sensor AKA stator or pickup coil (located inside distributor)
Mike
emongear
06-10-2007, 11:20 AM
Thanks! I will check these. How do you check the crankshaft position sensor?
wwwildman
06-10-2007, 08:23 PM
For Crankshaft position sensor try here: http://www.autozone.com/az/cds/en_us/0900823d/80/15/23/4d/0900823d8015234d/repairInfoPages.htm
For Camshaft sensor here: http://www.autozone.com/az/cds/en_us/0900823d/80/15/23/7e/0900823d8015237e/repairInfoPages.htm
COil and ingnition module: http://www.autozone.com/az/cds/en_us/0900823d/80/15/1b/21/0900823d80151b21/repairInfoPages.htm
Hope this helps.
