06-03-2007, 09:41 PM
Help, two wires, and no place to put them
My son and I replaced a burned out, used up 1.0 liter engine in a 91 metro convertable.
We have 2 wires that noone remembers where they came from. They have round terminal connectors, like the kind that would be held on by a screw or bolt. One is hot when the key is on.
We are at the point where the engine turns over, but doesn't start. If we pour gas in the throttle body, the engine will start, but stop as sone as the gas is gone. Any ideas?
I have pictures but have no way to attach them to this post.
06-04-2007, 02:24 AM
Re: Help, two wires, and no place to put them
they bolt on to intake next to throttle body. you won't get fuel if they are not grounded
06-05-2007, 12:07 AM
Even if one is hot?
On the egr side or the front. Just any bolt or anything specific?
06-05-2007, 12:26 AM
its hot because its its going through a relay thats supposed to be grounded to turn the fuel pump on. any bolt on the intake will work
06-05-2007, 12:27 AM
and i assume you mean small wires not a big wire like would go on the big terminal on the alternator
06-05-2007, 01:11 AM
Thanks, will give it a try. Yes, they are small, 12, 14 gauge, all other wires in their place.
06-15-2007, 12:20 PM
Thanks, this was the problem. the car started imediately.
Does any one know where is can get replacement headlights?? All i can find are sealed beams and i need the composite ones.
06-16-2007, 09:22 AM
Search E-Bay
E-BAY Geo Metro Headlights
1991 Geo Metro convertable LSI headlight
