really need help with my mr2 drag caralfa mr2 06-03-2007, 07:18 AM hi we have just finished rebuilding my drag car, alfa mr2 all is good except, that the car is massively overfueling on idle, i have been over everything completely time and time again, one problem is i have a completely aftermarket engine loom that spl built for my car, when it was in japan , so no colours correspond too diagrams, fuel pressure is fine at 3 bar on idle, injectors are working properly, i have a reworked stock ecu by spl and also from that a piggy backed hks f con v-pro a mistake was made when an earth was accidently connected to a live on the alternator and it blew the 7.5 amp ecu ignition fuse in the engine bay fuse box( not good)) hmmm:shakehead i think that the ecu's have been backfed i have changed the typical sensors and all seems fine now except for the overfuelling anyone know of anyway of clearing this,or anythng that may make this happen.:banghead: its probably something stupid, short of no luck here, im going to send the ecu's first off to a specialist to check the curcuit boards, and thento a hks pro writer garage to have the ecu looked at and see if the map still in there, the car was off the road for a fair while about 6 monthes, but all i have spoke to said the hks ecu will still have its map in it as e-prom ecus very reliable .. please help totb is looming and its about time the car made a point in the uk????? :evillol: ac427cpe 06-12-2007, 06:41 PM what engine are you running? with the amount of custom stuff you have goin on... it could be any number of problems. I would start by making sure the injectors flow the correct amount of fuel. alfa mr2 06-14-2007, 01:48 PM hi yeah thanks for the help, erm im running a custom engine that was commissioned by three companys , spl , jun, and speed house alfa, it was typically designed for drag , spec is quite comprehensive , and a custom made block for all the internals to go into, plus sleeved . hence its power output 754bhp , that was the old spec so its just going to dyno soon now it has new spec should be good,and everyones is sure of more, i had checked all the injectors etc,, i finally found out what the problem was fuel vapour has killed the throttle position sensor and was basically on wide open throttle , so ecu was fuelling accordingly, nice to meet you the names adam , drop me a mail at addmr2@hotmail.com or send add me to yourt msn!! Automotive Network, Inc., Copyright ©2012
