Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Venture
Old 06-03-2007, 12:54 AM   #1
scattmann
scattmann Normal reputation
Send a message via Yahoo to scattmann
00 venture rear blower does not work
00 venture rear blower does not work, it has been repaired but stops blowing I have checked fuse, rear blower cold/hot speed box has been replaced blower has been replaced but does not work do you know where it is located in the rear of the van? thanks any help appreciated
scattmann is offline   Reply With Quote
Old 06-05-2007, 05:00 PM   #2
bigcoconut
bigcoconut Normal reputation
Re: 00 venture rear blower does not work
The rear blower is located on the drivers side at the back of the van. You will have to pull the bottom rear hatch plastic cover (on the floor where the hatch locks) and the two rear post plastic covers (on either side of the rear side window). Then you can pull the large plastic cover on the left side of the van. You will also have to take out the seats and belts. Behind this you will find the HVAC Module.
To change the blower at this point is very simple. The blower will be the large round piece sticking out. Simply unplug the electrical wires to the motor. Then lift that tab at the top to allow the motor to rotate about an 1/8th turn and it comes out.
Hope this helps...
bigcoconut is offline   Reply With Quote
Bookmarks
Google
Web AF
